Wuzzie Posted November 16, 2005 Report Share Posted November 16, 2005 Just wondering, what is the best Vista / Aero skin around? And is there somebody working on a version for WB5? v5 will be a giant leap for customizekind It's a bit hard to know now that Aero-Soft is gone. Hopefully this section will be a good replacement. I'm first ever to post here :cool: ~Wuzzie Link to comment
djay_ Posted November 16, 2005 Report Share Posted November 16, 2005 hipersonally for me the best vista skin is made by kol.VistaXP v2 WB it's a great skin for windowblinds. it supports Transparency on window frames and titlebar buttons, Transparency on taskbar and much more by using windowblinds 5.it's free and kol updatest the style continuously.DJay Link to comment
kattenvenne Posted November 16, 2005 Report Share Posted November 16, 2005 Best Visual Style for Windows: VistaXP V2 VS by -kolBest WindowBlinds 5 Skin: Vista XP V2 WB by -kol (oops, allready mentioned...)Those two Skins/Themes work even nicer with the Vista Inspirated Shell Pack from CrystalXP.net Link to comment
Autumnmist Posted November 16, 2005 Report Share Posted November 16, 2005 Also Noire and Arrow:http://www.wincustomize.com/ViewSkin.aspx?...ID=5328&LibID=1http://www.wincustomize.com/ViewSkin.aspx?...ID=5347&LibID=1 Link to comment
sakurakira Posted November 19, 2005 Report Share Posted November 19, 2005 Bister is also pretty nice, if you like really dark themes. Susumu also has different color versions available here. Link to comment
Louie Mantia Posted November 27, 2005 Report Share Posted November 27, 2005 Wow, when did this forum get here?!// Lou Link to comment
idunno22 Posted November 27, 2005 Report Share Posted November 27, 2005 yeah bister, been using it since it came out, i love it Link to comment
vide12301230 Posted December 8, 2005 Report Share Posted December 8, 2005 Best Visual Style for Windows: VistaXP V2 VS by -kol and dreamland Link to comment
dave double u Posted December 8, 2005 Report Share Posted December 8, 2005 Best Visual Style for Windows: VistaXP V2 VS by -koland dreamland Hey, Vide. I'm probably just being ignorant but what's the theme in the attached picture, WIP? Link to comment
dorsc Posted December 8, 2005 Report Share Posted December 8, 2005 it's dreamland.. he said that Link to comment
Zaft Posted December 8, 2005 Report Share Posted December 8, 2005 The Arrow theme mentioned earlier in the thread is the one I'm using now, it looks great with WB5! :cool: Link to comment
firecracker6 Posted December 8, 2005 Report Share Posted December 8, 2005 @vide12301230,Where'd you come across your toolbar icons in your ss? I downloaded dreamland but the wbskin did not seem to come with the toolbar in the screenshot. I looked in the 'toolbars' section of the windowblinds configuration screen and indeed there's an entry for dreamland, however, the icons shown are the default windows XP ones. Any advice?EDIT: Figured it out: I just needed to edit the "DreamLand Subskin.ToolBarIcons" file since it had outdated directory paths to the toolbar image files. For anyone else who had the same problem, this is the fix. I really like this toolbar set, unfortunately, it's incomplete. But the reflection effect is very elegant. Anyone else know of a similar toolbar set they'd recommend? Link to comment
vide12301230 Posted December 9, 2005 Report Share Posted December 9, 2005 @vide12301230,Where'd you come across your toolbar icons in your ss? I downloaded dreamland but the wbskin did not seem to come with the toolbar in the screenshot. I looked in the 'toolbars' section of the windowblinds configuration screen and indeed there's an entry for dreamland, however, the icons shown are the default windows XP ones. Any advice?this is styler toolbar which i revises.use the ss across toolbar,the toolbar icon will Change slightly.Darker Theme.zip Link to comment
spclffred Posted December 9, 2005 Report Share Posted December 9, 2005 Well i have jemahos vista glass theme that was only released to about 500ppl, its the best ive used yet. Heres a screenie of my desktophttp://img473.imageshack.us/img473/2222/desktop12yo.jpg Link to comment
firecracker6 Posted December 9, 2005 Report Share Posted December 9, 2005 @vide12301230,thank you very much for sharing, I do not use stylertb but if ever i come around.. this will definitely be one of the reasons. Link to comment
SparXCG Posted December 10, 2005 Report Share Posted December 10, 2005 I like Arrow very much, using it right now. It comes with shadows, and there's also a shadowless subskin for those who prefer that. Link to comment
zondajag Posted December 10, 2005 Report Share Posted December 10, 2005 is there a transparent vista-like theme with a thin black taskbar? Link to comment
spclffred Posted December 10, 2005 Report Share Posted December 10, 2005 is there a transparent vista-like theme with a thin black taskbar? no u cant get Vista glass effect with any VS, the only thing that does that for windows right now is Windows Blinds 5, And so far i havnt seen any theme with glass and black taskbar. Link to comment
xdeskcal Posted December 13, 2005 Report Share Posted December 13, 2005 VS can not support png and glass effectI think only WB 5 can do it now. Arrow looks very like the vista , I think it is the best vista skin . Link to comment
co1063 Posted June 13, 2006 Report Share Posted June 13, 2006 http://i6.tinypic.com/14b2ids.jpgjemahos. its available to anyone at joejoe.org. best skin IMO. Link to comment
normr Posted June 18, 2006 Report Share Posted June 18, 2006 Have a look at Post Arrow Vista Borders from olegmontana at:http://forum.customize.ru/index.php?showtopic=1266&st=1003 download links included.See my DA for a screenshot.http://priapus2.deviantart.com/ Link to comment
normr Posted June 24, 2006 Report Share Posted June 24, 2006 jordygreen has just updated hisV53xx to v.3. It looks very good!See my June 24 Desk here:http://priapus2.deviantart.com/Get it here:http://www.deviantart.com/deviation/35238562/ Link to comment
normr Posted June 25, 2006 Report Share Posted June 25, 2006 olegmontana My Vista now on DA:http://www.deviantart.com/deviation/35321912/ Link to comment
normr Posted July 7, 2006 Report Share Posted July 7, 2006 Milork's Theme 1.1 Plus. See my screenshot here:http://www.deviantart.com/deviation/35910116/And get the theme here:http://www.deviantart.com/deviation/35769239/ Link to comment
