raduking Posted April 24, 2005 Report Share Posted April 24, 2005 I'll post here and edit the latest nightly builds for the upcomming version 0.41 Since these are nightly builds some of the features may not work or are disabled. These builds may not be as stable as the 0.4 Beta. I'm only doing this to show you that the development hasn't stopped . please do not post bug reports for nightly builds - thank you Build 282 - Download: http://home.cogeco.ca/~rklauncher/RK_Launc...eta_Nightly.zip what's new in version 0.41 Beta: - all files are built with Visual Studio 2005 - switched from MFC to WTL/ATL RKLauncher.exe - fixed several OD docklets bugs - added restore windows support - added minimize position, new applications position settings - fixed RK Launcher accessing the HDD every second - added minimized window menus - fixed OD docklets sometimes crashing on removing - fixed draging files onto items when dock locked - added language support (language files in the 'lang' directory) - added show minimized window icon option - added Menu tab in Settings - added "Show in Explorer" option for folders (click+Hold) - added some more options to the folder view - smooth item move - updated Position settings - fixed shortcuts for Office, WLM, etc... - added Alt+Tab support for restoring minimized windows - all "conf" files are now Unicode UTF-16 LE Only features enumerated here work in the latest release. This release adds the first version of ObjectDock docklets support that may contain a lot of bugs. I will open a new thread in the future for bug reports when I fix most of them. Link to comment
raduking Posted June 8, 2005 Author Report Share Posted June 8, 2005 when getting a new build and you want to keep your settings you can keep theitemlist.conf file and the RKLauncher.conf file with the folowing note:- look here for the new additions to the file (marked in red)RKLauncher.conf----------------------[settings][Language]langResource = rkl_english.lang[Appearance]magnifySize = 92smallSize = 48itemDistance = 0magnification = 1backgroundAlpha = 150itemsMagnify = 7# removed: position = 4theme = DefaulthideIndicators = 0hidePoofs = 0[Position]position = 4positionMargin = 0multiMonitorSupport = 0[behavior]alwaysOnTop = 0locked = 0automaticHide = 0saveOnExit = 1saveOnChange = 1saveItems = 1itemAnimation = 0itemAnimationCount = 5itemAnimationNew = 1minimizeToDock = 1useMinMaxEffect = 0minMaxEffect = RKScaleEffect/RKScaleEffect.dllminimizePosition = -2newApplications = 0newIconsPosition = -4hideTaskbar = 0useMarginHotspot = 1hotspotDelay = 250hotspotFullMargin = 1neverTakeFocus = 0showMinimizedWndIcon = 1startWithWindows = 0swwRegistry = 1swwUser = 0[Menu]showInExplorer = 1showInExplorerLabel = Show in ExplorerhideFileExtension = 1onlyRegistered = 0showSettingsAllItems = 0[Label]font = TahomafontSize = 12bold = 1italic = 0colorLabel = 16777215colorEdge = 0colorShadow = 0alphaLabel = 255alphaEdge = 225alphaShadow = 205hideLabel = 0fadeLabel = 0--------------------Note: make sure you have all the fields enumerated here, otherwise some options my not work Link to comment
raduking Posted March 8, 2006 Author Report Share Posted March 8, 2006 Nightly Updated! Link to comment
raduking Posted April 10, 2006 Author Report Share Posted April 10, 2006 Nightly Updated! Link to comment
raduking Posted April 18, 2006 Author Report Share Posted April 18, 2006 New nightly build 246 (fixed bugs that appeared after changed to VS2005) Link to comment
raduking Posted June 30, 2006 Author Report Share Posted June 30, 2006 New build: 253please make sure you update RKLauncher.conf Link to comment
raduking Posted July 4, 2006 Author Report Share Posted July 4, 2006 new build: 255 - fixed minimize bug from 253LNB: build 256 Link to comment
raduking Posted July 7, 2006 Author Report Share Posted July 7, 2006 LNB: buld 258 (launching items put in separate thread) Link to comment
raduking Posted August 14, 2006 Author Report Share Posted August 14, 2006 new build - 274those who have win2000 tell me please if this build works thx Link to comment
raduking Posted August 14, 2006 Author Report Share Posted August 14, 2006 build 275 up Link to comment
raduking Posted March 16, 2007 Author Report Share Posted March 16, 2007 build 282 up Link to comment
