[question] RK Launcher
Just tried XP SP2 Start Docklet http://www.wincustomize.com/ViewSkin.aspx?...D=5539&LibID=29 but it disappears just as soon as it pops up. I'm running SP1, so you may want to check it out on an SP2 system. This is running on the newest 0.4 beta.
Also tried Startmenu Docklet http://www.wincustomize.com/ViewSkin.aspx?...D=2373&LibID=29 , which as soon as I click add dock I get a "rklauncher needs to shut down" message and the whole things goes kaput.
Shutdown docklet works great though, just haven't figured out how to rename it.
I wonder if the Startmenu Docklet making RKL crash because the XP SP2 Start Docklet is also installed? I can't figure out how to remove the XP SP2 docklet so I can't test it, but I'll post when I figure it out.
Edit: Nope, nothing to do with XP SP2 Start Menu installed.
Thanks Radu!
