profeten Posted June 17, 2005 Report Share Posted June 17, 2005 yeah i know, Systats already have a network monitor and i love it as h**l but i doesnt show how much that have been downloaded/uploaded and it would be really fun to see these figures ..i've seen a docklet for Samurize that does this so it shouldnt be impossible for Systats to do this to ..soo ..how do I/we fix a docklet/script that does this then Link to comment
Ellada Posted June 17, 2005 Report Share Posted June 17, 2005 Is this what you are looking for? Link to comment
S@m Posted June 17, 2005 Report Share Posted June 17, 2005 is there a netowrk meter that could get from a networked dsl? Link to comment
profeten Posted June 17, 2005 Author Report Share Posted June 17, 2005 naa ..already checked that one out and it only shows history for the up/down speed ..i wanna see how much i've downloaded/uploaded ..like this Samurize script is showing --> http://www.deviantart.com/view/3998905/ ..check out the Sent/Received, thats what i want to see Link to comment
cthoffm Posted June 18, 2005 Report Share Posted June 18, 2005 It's not that hard to add it yourself.The PDHMeter class is capable of getting a wide range of values from the network adapters including totals up/downloaded.As far as the 'networked DSL' is concerned, I'm not sure what is being asked... Do you mean a DSL box that is connected to the PC via ethernet? In that case you setup the PDHMeter to look at the NIC that is being used to connected to the DSL box.HTH Link to comment
g8trtim Posted June 18, 2005 Report Share Posted June 18, 2005 I dont know if this is on topic really, but I'm looking for a config which will access my router to tell me who is active on my network... i live in an apartment and I want to know when/if people access my network, without popping into my router config myself... anything available for samurize? Link to comment
profeten Posted June 18, 2005 Author Report Share Posted June 18, 2005 It's not that hard to add it yourself.The PDHMeter class is capable of getting a wide range of values from the network adapters including totals up/downloaded.As far as the 'networked DSL' is concerned, I'm not sure what is being asked... Do you mean a DSL box that is connected to the PC via ethernet? In that case you setup the PDHMeter to look at the NIC that is being used to connected to the DSL box.HTHalready searched through PDHMeter and stats for download/upload wasnt in there (just a history of up/down speed) Link to comment
cthoffm Posted June 18, 2005 Report Share Posted June 18, 2005 OK, my mistake, you are right. It's the total *per second*.One workaround that comes to mind is to write a script that keeps the totals for you. Link to comment
profeten Posted June 18, 2005 Author Report Share Posted June 18, 2005 thought of that, but i know s**t about scripting so Link to comment
cthoffm Posted June 19, 2005 Report Share Posted June 19, 2005 If you have a config that you like, I can probably modify it for you.Post a link or attach it here if you like... Link to comment
cthoffm Posted June 21, 2005 Report Share Posted June 21, 2005 i live in an apartment and I want to know when/if people access my network, without popping into my router config myself... anything available for samurize?Only just saw this...It's not likely that any external monitoring utility can access this info without some considerable effort because your router doesn't expose it's internal workings to windows. I don't rate your chances highly.It *may* be possible with some fancy HTML/XML coding but it would take a better person than I. Link to comment
g8trtim Posted June 21, 2005 Report Share Posted June 21, 2005 aight thanks, I didnt know if it was possible and its surely beyond my comprehension... Link to comment
