patstome Posted January 3, 2006 Report Share Posted January 3, 2006 hi @ all.i can't find anything in other threads...exist a docklet to add the run dialog box to rk? i tried to drag & drop a shortcut, but this isn't working.any ideas? thx in advance patstome Link to comment
testos Posted January 3, 2006 Report Share Posted January 3, 2006 Lets see, make script to do Win+R, perhaps?That or a run box replacement. Link to comment
ziptrx Posted January 3, 2006 Report Share Posted January 3, 2006 Have you tried this ObjectDock docklet?http://www.wincustomize.com/ViewSkin.aspx?...D=4600&LibID=29 Link to comment
Hiub Posted January 3, 2006 Report Share Posted January 3, 2006 Do a search on google for openrun.exe, that should do what you want. Link to comment
patstome Posted January 3, 2006 Author Report Share Posted January 3, 2006 @ ziptrxthis could be what i was looking for, but unfortunately it does't work@ hiub if i google "openrun.exe" there are 3 results only, hmmm... and nothing i can work with (maybe you)@ vkeiosif i know how i had made one... and what about "run box replacement?but thanks for your time Link to comment
gtn Posted January 3, 2006 Report Share Posted January 3, 2006 An oldie but a goodie: Run95 (http://www.flos-freeware.ch/misc.html)Standalone EXE that emulates the functionality of a dialog. Link to comment
patstome Posted January 3, 2006 Author Report Share Posted January 3, 2006 An oldie but a goodie: Run95 (http://www.flos-freeware.ch/misc.html)Standalone EXE that emulates the functionality of a dialog.thank's very much... this is what i was looking for and i can use.feel free to ask me something else, maybe i can pay back Link to comment
Hiub Posted January 5, 2006 Report Share Posted January 5, 2006 Glad you found it, the app I was talking about is just like that one. It also came with an shortcut to open the "Shut Down" dialog which was neat. Let me know if you want them and I will send them to you. Link to comment
patstome Posted January 5, 2006 Author Report Share Posted January 5, 2006 @ hiub,thanks for your offer, but i still got it with the link from gtn here Link to comment
chermany4ever Posted July 27, 2006 Report Share Posted July 27, 2006 That replacement must work great on win98 or NT... but it doesn't on XP. XP users do this: create a shortcut of the Run Dialog (drag it from the startmenu) to your desktop, cut it and paste it anywhere you want, and drag it over the dock. Link to comment
patstome Posted July 27, 2006 Author Report Share Posted July 27, 2006 well, i'm still using XP, and the run95 .exe file is working great here . and your suggestion isn't working. that's why i started this thread. i can drag and drop the shortcut to the dock how often i want, but nothing happens when i click on it. sure you can use it? Link to comment
chermany4ever Posted August 1, 2006 Report Share Posted August 1, 2006 Yeah... it works perfectly. Just make sure to make a shortcut to the desktop or any folder first, not the dock. Then, drag that shortcut into the dock. Works for me. The replacement is not working here. I'm using Windows XP SP2. Link to comment
piniata Posted August 1, 2006 Report Share Posted August 1, 2006 Really nice one I just downloaded is called SysCmd, and it allows you to choose from 16 system commands including Run, Find etc. from a right click. The last option you chose becomes the default whenever you left-click it - it's really very very helpful!! Link to comment
patstome Posted August 1, 2006 Author Report Share Posted August 1, 2006 Yeah... it works perfectly. Just make sure to make a shortcut to the desktop or any folder first, not the dock. Then, drag that shortcut into the dock. Works for me. The replacement is not working here. I'm using Windows XP SP2. well, okay, i was using xp sp2 as well, but it doesn't matter for me right now... i'll wait for the 10th of august for my new Imac and everything will by allright then Link to comment
