toxicated555 Posted January 29, 2008 Report Share Posted January 29, 2008 Hey, how come when i select the option to show the system tray on the right/left side of my dock, nothing shows. I am using windows vista business. I have tried the Objectdock Tray by Nimix, but i do not get how come it does not show network, since it can only show 4 icons in system tray? Link to comment
aaronjreeves Posted November 15, 2008 Report Share Posted November 15, 2008 same problem... i went ahead and downloaded "ObjectDock Tray Version 2.10" it works nice and from what ive heard works better than having a whole bunch of full sized icons as your tray... it contains all the little (well, normal sized) tray icons with 1 single OD icon. Link to comment
Smaky Posted November 19, 2008 Report Share Posted November 19, 2008 Same thing here... ObjectDock Tray Version is the solution I found too Link to comment
Raginwald Posted November 27, 2008 Report Share Posted November 27, 2008 I have found another one, called 'TrayStack' on http://www.chrisnsoft.com/This puts all the systray icons in a (standalone) stack, so they will only be shown after you click the stack.I prefer this one because i dont like all those little icons on my dock Link to comment
Abbas Posted February 7, 2009 Report Share Posted February 7, 2009 I have found another one, called 'TrayStack' on http://www.chrisnsoft.com/This puts all the systray icons in a (standalone) stack, so they will only be shown after you click the stack.I prefer this one because i dont like all those little icons on my dockI downloaded this but cant figure out how to install it. Basically, I copied the Docklet Directory inside ObjectDock/Docklets and I can see "Add Stack" but its empty. I couldnt find any instructions- would appreciate if you could provide a guide on how it works Link to comment
matonga Posted February 7, 2009 Report Share Posted February 7, 2009 @Abbas:Right click your dock, select Add Item > File, then choose TrayStack.exe. Link to comment
