BOBAH13 Posted September 21, 2008 Report Share Posted September 21, 2008 Options Support languages ("Languages*.xml") Support skins ("ToolsXSkinMaker.exe and Config.txt") also you can get images from "SkinsCurrent*.png" Start with windows Can edit file's types for sort them, such as: Video, Audio, Picture, Text Transparency of icon's reflection 0..100% Icon's size 32..100 pixels Icon's size when mouse is over 32..100 pixels Maximum icons in stack 8..18 Space between reflection and icon -5..5 Transparency of panel 0..100% Panel will hide in 0..3600 seconds Space between panel and screen 0..100 pixels Space between icons 0..10 Show indicators of applications in system Hide stack when it's deactivated Minimize windows into the dock. It supports 2 effects: Default and Genie. Also you can change speed for minimize them Reaction to change directory. So when directory'll be changed dock's item jump or not. You can set options, such as: Added, Removed, Modified, Renamed Option to change position of dock. Above all windows or not Change icon's size of stack's grid ( 70-150 pixels ) Option to show item's shadow Option to change position of dock on top when mouse is over 2 methods what do when icon was droped out. You can use: create link or poof. Cans Add File. Select some file(s) in dialog from you PC and then it'll be added into the dock. Directory. It sames File. Separator. It's a break among dock's items. Stack. You can create private stack or publish. In private you can add everything what you want. Publish stack, you can't change, because it joins Explorer direcotry. Can add speacially directories, such as: My computer, Control panel and Trash. You can work at trash as when you work at original one. If you have docklets created for this dock, you can add them too. Add into stack. This option looks like the Add. Edit. You can change item's icon, caption, command line, work directory, parameters. Delete. This is a simple option. Stack Sort. You can select method for sort stack's items. Name, Date (Changed, Created, Accessed) and Kind. It sorts by kind using option "File Types", where you wrote your file types extensions. View. It shows how you would like to view stack. When you select Auto, the dock select Fan or Grid alone or you also can use Menu method. Stack's icon. It's a very interesting option. Here you can set some icon which will be showed over the stacks, onto the dock. You can see some icons in "SkinsBox*.png" [*]Drag & Drop into the dock and out. [*]Move items among them. [*]Preview of item which is moving over the dock [*]Support hover item for stack's grid [*]About. This option shows about developers and people who helped with this dock. So when you decided make skin for XWindows Dock, you should know it: XSkinMaker version 2.5 name; size ( Width x Height pixels ) ; Can use transparency ( ALPHA - channel ); Break 14x40 Yes Close 48x48 No Left ?x40 No Middle ?x40 No Right ?x40 No ControlPanel ?x? ? MyComputer ?x? ? Recycler ?x? ? RecyclerFull ?x? ? StackOn ?x? ? StackOff ?x? ? Poof ?x? ? Where you can see "?" it's mean that you can use what you want. Futures news won't be publish here because the site to support this dock will be started as soon as it's done Link to comment
KAWSquared Posted September 21, 2008 Report Share Posted September 21, 2008 When will the Mirror effect be available? Link to comment
BOBAH13 Posted September 21, 2008 Author Report Share Posted September 21, 2008 I don't know yet. It's working, but not so well and I have got some bugs, it's about windows. For the icons, I did mirror effect. Sorry for mt english, it's not easy for me to talk Link to comment
KAWSquared Posted September 21, 2008 Report Share Posted September 21, 2008 So the mirror effect works on the icons, but not the windows? Link to comment
iCC Posted September 21, 2008 Report Share Posted September 21, 2008 I did mirror effect. Nice! Link to comment
BOBAH13 Posted September 21, 2008 Author Report Share Posted September 21, 2008 2 KAWSquared: yes, you are right. I'll do mirror effect for windows soon Link to comment
csongi Posted September 21, 2008 Report Share Posted September 21, 2008 I like it, works very beautiful, congratulations! I would like to see in the next version the poof effect when dragging out an icon from the dock, It would be great to add a file path for png icons to change the item's icons to be smoother, I can't wait for the window reflection and some other minor fixes would be great.. good work buddy, keep going forward Link to comment
ArchDevil Posted September 21, 2008 Report Share Posted September 21, 2008 dloading edit: WHOA!! it's mirror effect is working for icons and it has a native stacks. i think i wll switch rklauncher with that when it's little bit mature thank you very much for all your efforts:) Link to comment
BOBAH13 Posted September 21, 2008 Author Report Share Posted September 21, 2008 Thanks here it is language's source ( .dll ). It must be in a new version. I use pascal and I ask you translate it into other languages. It's already translated into english and russian. If you translated it, please send me new pas file, my mail bobah_uk@mail.ru thanks I'll publish a new file of language with a new strings there. Because I have got new ideas, thanks for you Link to comment
Ghostwalker Posted September 21, 2008 Report Share Posted September 21, 2008 It is a very nice start but will it be able to use docklets? Objectdock Docklets/YZ Docklets? I do like the built in stacks and the mirror effect but this dock has a long way to go to replicate the mac dock. Thank you for your effort I know building a dock is very difficult, will be watching the development of this. Link to comment
BOBAH13 Posted September 21, 2008 Author Report Share Posted September 21, 2008 Why do you want to use docklets of other docks ? What can they do ? I'll think about it. Link to comment
Ghostwalker Posted September 21, 2008 Report Share Posted September 21, 2008 Why do you want to use docklets of other docks ?1. The trash docklet made for YZ Dock (used in RKLauncher) has a context menu that has access to Norton.2. MSN Messenger3. Network Bandwith Docklet4. Volume Docklet5. Printer Docklet6.Mail Docklet.I could go on and on but what it comes down to is for me the thing I find the most useful from the dock is the docklets. Also there has been a lot of work put into docklets by developers. I dont think you would want to code all of the things you could get from docklets into your dock by yourself. There will come a day when you no longer wish to develope for this dock when that day comes others might still want to develope docklets for it.That I believe is what keeps docks moving right along. Link to comment
Phoshi Posted September 21, 2008 Report Share Posted September 21, 2008 This is pretty great, for such an early beta Icon reflection, imo, should be a bit more obvious, but the stacks are great! Pretty fast, too Link to comment
manufn619 Posted September 21, 2008 Report Share Posted September 21, 2008 dude this is pretty awesome Link to comment
BOBAH13 Posted September 21, 2008 Author Report Share Posted September 21, 2008 Ok I agree with you. I'm doing a new version with a lot of interesting things in my dock. I think. you will like it p.s. I started programming this dock only at begin of september I uploaded only a screen without a porgram about new version 3.0. You can see it here http://nemecsx.narod.ru/Images/ExmapleNewDock.png Link to comment
Ghostwalker Posted September 21, 2008 Report Share Posted September 21, 2008 @BOBAH13 Just thought you should know the site you posted your screenshot at has been rated Dangerous by WOT.http://www.mywot.com/ Link to comment
fortyfeet Posted September 21, 2008 Report Share Posted September 21, 2008 WOW.. really nice. I'm excited for the future of your program! Link to comment
schmrom Posted September 21, 2008 Report Share Posted September 21, 2008 Okay, I made a skin for it. It looks exactly like the Mac OS X Leopard Dock. If someone wants the 2D Version, just tell me Download here: http://www.file2go.net/view/7fdf1a4248 Link to comment
manufn619 Posted September 22, 2008 Report Share Posted September 22, 2008 @schmrom How do you make the skins...i put the SkinCompiler.exe in the command prompt but i don't know how to edit it Link to comment
pedromonge Posted September 22, 2008 Report Share Posted September 22, 2008 whoa! This dock is cool!edit: Great skin schrom! how did you make it?edit2: the icons look funky. They need some work. I would also like if you could add a right click menu to the recycling bin, and finally... make the icons poof instead of creating a shortcut, or at least add an option. Link to comment
schmrom Posted September 22, 2008 Report Share Posted September 22, 2008 whoa! This dock is cool! edit: Great skin schrom! how did you make it? Theres a skincompiler in the first post and then I just used Photoshop and created the graphics Link to comment
pedromonge Posted September 22, 2008 Report Share Posted September 22, 2008 I dont get how to use it. Link to comment
manufn619 Posted September 22, 2008 Report Share Posted September 22, 2008 I dont get how to use it.lol, me either i double clicked on the .exe file but nothing happened Link to comment
schmrom Posted September 22, 2008 Report Share Posted September 22, 2008 the skincompiler is a commandline toolyou need to do your graphics in photoshop and then start the tool with "SkinCompiler.exe Config.txt" Link to comment
