my left hand Posted July 10, 2004 Report Share Posted July 10, 2004 I dont know where else to ask but the community here is the most hardcore bunch of win hackers i know so here are some things that i absolutely would love to do but dont know how. i hope some of you would like these as well. two of these questions i am absolutely sure can be done, just dont know the method 1. how do i create a shortcut (that i can place on my object dock) that can start my screensaver? *i feel almost idiotic for asking this one...* 2. how do i eliminate the 3d borders/edges of any and all Explorer's windows? i believe i saw this in screenshots of the panther pack, but i didn't download that because it changes far more than just this. 3. can i use Luna's toolbar/menubar background bitmap using the Classic theme? i'm refering to the subtle white gradient in the background of toolbars, menubars, etc. please help, and thanks for reading the post. Link to comment
lostspyder Posted July 10, 2004 Report Share Posted July 10, 2004 1. why not just set your SS to start after 3 minuts of idel, then it doesnt take up a big spot2. its usualy in the visual style/WB4 skin3. i dont get it but i think youd have to make a custom skin Link to comment
my left hand Posted July 10, 2004 Author Report Share Posted July 10, 2004 Originally posted by lostspyder+Jul 10 2004, 08:31 AM-->QUOTE(lostspyder @ Jul 10 2004, 08:31 AM)1. why not just set your SS to start after 3 minuts of idel, then it doesnt take up a big spot<{POST_SNAPBACK}>yeah, i did have it set to 5mins once, but i watch a lot of quicktimes, mainly my own and so i've lengthened the start time to 9mins. but i love my SS lol and just wanted a way to boot it. Link to comment
schaggo Posted July 10, 2004 Report Share Posted July 10, 2004 Originally posted by my left hand@Jul 10 2004, 09:44 AM1. how do i create a shortcut (that i can place on my object dock) that can start my screensaver? *i feel almost idiotic for asking this one...*<{POST_SNAPBACK}>screensavers are usually *.scr files located in your Windows\System32 directory. If you know which screensaver to start, you can simply create a shortcut to that SCR file.at least I guess so... Link to comment
Hobbes Posted July 10, 2004 Report Share Posted July 10, 2004 ScreenSaver Just find the screensaver file. It should be somewhere in your Windows or Windows\System32 Directory. Make a shortcut to it and drag it to your dock. Window Borders I don't think you can just change the width of borders to 0 pixels unless you edit your WB skin / Visual Style. I believe Danimators Panther WB skin has 0 pixel borders. ToolBar Bitmap You can change the toolbar bitmap by a simple reghack. I'm not sure exactly which key you have to change. I had a toturial for it somewhere but I'm afraid I can't find it right now. If I come across it later I'll give it to you. Good luck -ifido Link to comment
Ghostwalker Posted July 10, 2004 Report Share Posted July 10, 2004 I use xHotspot gives you a hotspot in any corner of the screen you want just place your mouse over the corner and your screensaver will activate after a set time works great. Link to comment
my left hand Posted July 10, 2004 Author Report Share Posted July 10, 2004 Originally posted by Ghostwalker@Jul 10 2004, 11:51 AMI use xHotspot gives you a hotspot in any corner of the screen you want just place your mouse over the corner and your screensaver will activate after a set time works great. <{POST_SNAPBACK}> thanks for the help guys! yeah, i got the screensaver finally attached the link to an 8ball icon. check out http://www.refreshreload.com/, thats why i love the screen saver its not particularly mac, but its very much about graphic design by great designers, i think many of you here would dig it what that screen saver does is, everytime its started, it'll display a piece of work by a designer who's submitted their graphics to that website. so you'll barely ever see the same thing twice. - yeah the border being 0px thing, i was hoping i wouldn't have to use a wb skin, but i'll keep an eye out/think about using it if i cant resist the urge any longer. the reghack sounds pretty cool, i wanted to use as much of the default content as possible in the hopes that barely any resources'll be used in the process. thanks again guys Link to comment
