reaperxx Posted June 19, 2009 Report Share Posted June 19, 2009 Hey,everytime i open finder bar it is always transparent how do i fix this.and also is there anyway i can get my windows to look more like this on my pc i want the same look. (if that made any sense) Ps i have the whole mac look already but i wanted the open window txt to be centered and the red yellow green buttons close together like a real mac with that little rectangle thingy on the side. help plz Link to comment
cjborodin Posted June 29, 2009 Report Share Posted June 29, 2009 yeah i can't use it on vista. either the text is transparent, or finderbar loads really strangely where it gets rid of the minimized windows -like it's supposed to- but that's all it does. if i kill it in task manager, it doesn't do anything and i have to restart explorer.has landvermesser abandonded this program? this is my favorite mac bar emulation! Link to comment
ak47whaaa Posted October 11, 2009 Report Share Posted October 11, 2009 there is a bug with finderbar, if u select make windows menus transparent then it will not display any of the applications opened after that point i am using XP service pack 3 i hope u can fix this bug Link to comment
Björn Posted October 13, 2009 Report Share Posted October 13, 2009 That works here (XP SP3). Link to comment
david123 Posted November 28, 2009 Report Share Posted November 28, 2009 where can i get old versions of finder bar Link to comment
WWEExpress Posted June 12, 2010 Report Share Posted June 12, 2010 Hello, I just downloaded Finderbar Engine 1.5. I have Windows 7 Home Premium. Whenever I open Finderbar it doesn't look nice. It overlapped my former taskbar.How can I get it to look normal. Link to comment
josh16 Posted June 13, 2010 Report Share Posted June 13, 2010 I have the same problem as the post above me. The text and menu loads, but it just shows on top of windows normal taskbar, instead of taking the look of the macs. Anyone have any insight? I'm using xp. Link to comment
mps69 Posted June 14, 2010 Report Share Posted June 14, 2010 Not sure if this will work for Windows 7 as the application was developed before this OS was ever released so it's a bit of suck it and see, but it will work with XP, right click the Finderbar, and select "Skin it".As a side note, most of these types of questions have been asked numerous times here, try reading the thread before posting. Link to comment
IzzIsHOr Posted June 14, 2010 Report Share Posted June 14, 2010 (edited) Not sure if this will work for Windows 7 as the application was developed before this OS was ever released so it's a bit of suck it and see, but it will work with XP, right click the Finderbar, and select "Skin it".Sure it does work on Windows 7, even Windows 7 x64... look at my current set-up./>http://izzishor.deviantart.com/art/Windows-7-x64-as-Leopard-OSX-167621980 Edited June 14, 2010 by IzzIsHOr Link to comment
Bjoern Posted June 16, 2010 Report Share Posted June 16, 2010 The Finderbar makes a screenshot of your taskbar and uses this. You have to have a skinned taskbar before or change the background.png in the finderbar folder. Link to comment
jpenguin Posted August 28, 2010 Report Share Posted August 28, 2010 (edited) I;ve installed />http://www.mascobz.com/best-snow-leopard-transformation-pack-for-windows-7/ why does finderbar look like this... Edited August 28, 2010 by jpenguin Link to comment
thatguy009 Posted August 28, 2010 Report Share Posted August 28, 2010 Because it skins you taskbar, your taskbar is that size so finderbar will be that size Plus it wasn't made for Windows 7 Link to comment
mareel3 Posted October 16, 2010 Report Share Posted October 16, 2010 I have installed, skinned and put finderbar at the top of my desktop but it is blue instead of white. How do I make it white with the apple icon?Moved - mps69 Link to comment
Evilegg11 Posted October 26, 2010 Report Share Posted October 26, 2010 The Finderbar when I changed the task bar to "not transparent" won't change to black. Skin it! doesn't work. I tried. Help! I am running Windows 7 Ultimate. Link to comment
romeooh Posted January 28, 2011 Report Share Posted January 28, 2011 Hi guys,is there any way to show all open windows on finderbar?i can only make show active window.thanks Link to comment
