[release] Sinapse v0.1
siwu
i downloaded sinapse after a friend demo'd it for me on his laptop. however, once i have the program installed it won't actually do anything. it'll run, but the activation keys don't work. i went into the configuration panel and tried to set key combos and it didn't seem to register any of them, and none of the hot corners are working, either. what's wrong?
i'm running XP SP2 and i've got a radeon 9700 so it can't be a graphics problem... the program itself runs without a problem but it doesn't seem to want to take input. what's going on here?
  • Replies 144
If Sinapse works it is nice, but unfortunately after some time it always crashes. Also the dimmed windows are too dark. If Sinapse is activated by a mouse button or key stroke and the mouse pointer happens to be over a window in Sinapse's overview, you can't tell well what is shown in the other windows now dimmed by Sinapse.
Thanks for the nice tool and please continue your efforts!
Miles
Sinapse's crash dump:
(My computer is running Windows xp sp2, dx 9.0c, Catalyst 4.12 and I'm using Microsoft's Virtual Desktop Manager (MSVDM))
Assembly Full Name: Sinapse, Version=1.0.1832.23750, Culture=neutral, PublicKeyToken=null
Assembly Version: 1.0.1832.23750
Exception information:
Exception Type: Microsoft.DirectX.Direct3D.InvalidCallException
Exception Source: Microsoft.DirectX.Direct3D
Exception Message: Error in the application.
Exception Target Site: Reset
Stack Trace information:
Microsoft.DirectX.Direct3D.Device.Reset
Sinapse.Core.SinapseWindow.AttempRecovery
Sinapse.Core.SinapseWindow.Render
Sinapse.Core.SinapseCore.Render
Sinapse.SinapseMain.Main
Hi all, I'm new to this. first of all, thanks to SIWI for this incredible program. Works great for me. For those of you who can't get Y'z Dock excluded, I know how. After you have done the cool drag and drop thing, and saved it, open up the config file. Find the spot in the config that says NAMEwhere NAME is the name of the Y's Dock class. remove it so that it reads just and it will be discluded. I don't know why this works, but it does. Also, for some of you others who are having problems, remember you need to be on windows XP, and need to have that font monotype corsiva lol.
hey siwu, just to let you know, i'm getting this crash error as soon as i run sinapse. i already installed .net 2 beta as well
System information:
Machine Name: FUZZ
OS Version: Microsoft Windows NT 5.1.2600.0 Service Pack 2
Manufacturer: NVIDIA
Model: AWRDACPI
System Type: X86-based PC
Total RAM: 2047MB
Processors Count: 1
-AMD Athlon 64 Processor 3000+ at 1808Mhz
Bios: Nvidia - 42302e31
Current Date/Time: 2/15/2005 8:51:37 AM
TimeZone: (GMT-05:00) Eastern Time (US & Canada)
Graphic information:
Device: 0
Name: NVIDIA GeForce3 (Vstudios Xtreme G Quality)
GDI Name: .DISPLAY1
Display Mode: 1600x1200 at 75Hz X8R8G8B8
Revision: 163
SubSystem ID: 1b1545
Vendor ID: 10de
WHQL Level: 0
GUID: d7b71e3e-4140-11cf-256d-112002c2cb35
Driver: nv4_disp.dll
Driver Version: 6.14.10.7120
MultiSample Types: None, NonMaskable,
Max Texture Size: 4096x4096
Max MultiTexturing: 4
Non ^2 Textures: True
Device: 1
Name: NVIDIA GeForce2 MX 100/200 (Vstudios Xtreme G Quality)
GDI Name: .DISPLAY2
Revision: 178
SubSystem ID: 0
Vendor ID: 10de
WHQL Level: 0
GUID: d7b71e3e-4251-11cf-6078-0a2013c2cb35
Max Texture Size: 2048x2048
Max MultiTexturing: 2
Assembly information:
Application Domain: Sinapse.exe
Application Path: C:Documents and SettingsFuzz NorelidDesktopSinapse_v0.1
Application Codebase: file:///C:/Documents and Settings/Fuzz Norelid/Desktop/Sinapse_v0.1/Sinapse.exe
Exception Type: Microsoft.DirectX.Direct3D.OutOfVideoMemoryException
Exception Target Site: CreateSurfaceFromBitmap
Microsoft.DirectX.Direct3D.Surface.CreateSurfaceFromBitmap
Microsoft.DirectX.Direct3D.Surface..ctor
Sinapse.Core.SinapseWindow.InitializeDirect3D
Sinapse.Core.SinapseWindow.InitWindow
Sinapse.Core.SinapseWindow..ctor
Sinapse.Core.SinapseCore.CreateSinapseWindows
Sinapse.Core.SinapseCore..ctor
Sinapse.Core.SinapseCore.GetInstance
hi guys im new to this but im really into your expose clones they rock, well anyway heres what i wanna ask you, i really love sinapse, the animations are good and the way it resizes all the windows you have, but theres one thing that would make it better than anything out there and thats if it could show minimized windows too, like just by pressing f9 it would bring evey window into xpose...even minimized ones, i know iEx does this so why doesnt sinapse??? if you can alter a .ini file for me so that it can show every single window including minimised ones, then as i say it would be the best expose clone out there....see what you can do, and keep up the good work....email me with the ini file if you can at christopherbezak@hotmail.com cheers
I kept getting an out of memory exception on my Laptop with 1920X1200 on Geforce 4200go 32mb. I mad e the screen resolution 1024X768 and ran sinapse and if worked great. I then made the resolution 1920X1200 and sinapse still worked, but only in a 1024X768 box. This is fine with me. Is there a way to include in the gui or the config.xml to make sinapse use a lower resolution? This way it would still be useful to us who have higher screen resolutions.
Great work. The app runs great on my desktop (GF 6800 GT @ 1920x1200) and fairly well on my laptop (GF 5200 @ 1400x1050).
Some bugs:
1) The app crashes if you run it while another instance is already running in another user session.
2) The app crashes if the config file points to the wrong directory for script/organizer files. I think some more graceful error handling would be nice in a future release :)
hi... i'm getting this error every time i try to expose a window :(
Exception Type: System.ArgumentOutOfRangeException
Exception Source: mscorlib
Exception Message: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
Exception Target Site: ThrowArgumentOutOfRangeException
System.ThrowHelper.ThrowArgumentOutOfRangeException
Sinapse.Core.SinapseCore.StopExposing
Sinapse.Core.SinapseCore.GlobalKeyUp
Sinapse.Core.SinapseHooksForm.WndProc
System.Windows.Forms.Control+ControlNativeWindow.OnMessage
System.Windows.Forms.Control+ControlNativeWindow.WndProc
System.Windows.Forms.NativeWindow.Callback
Any news Siwu?
It's been about 2.5 months since this release, and for those who have used it, we can all agree it's looking pretty good... but has the trail gone dead again? :(
Well the thing is I definitely didn't have time to continue the development of Sinapse. Eventually I'll release the sources if I can't continue development.
  • 2 months later...
  • 3 weeks later...
a fatal error has occurred:
System information:
Machine Name: TOMLAPP
OS Version: Microsoft Windows NT 5.1.2600 Service Pack 2
Manufacturer: eMachines, Inc.
Model: Imperial
Total RAM: 765MB
Processors Count: 1
-Intel® Pentium® 4 CPU 2.40GHz at 2392Mhz
Bios: PTLTD - 6040000
Current Date/Time: 6/29/2005 2:50:07 PM
Device: 0
Name: NVIDIA GeForce4 MX 440
GDI Name: .DISPLAY1
Display Mode: 1152x864 at 70Hz X8R8G8B8
Revision: 163
SubSystem ID: 0
Vendor ID: 10de
WHQL Level: 0
GUID: d7b71e3e-4231-11cf-a57f-0a2002c2cb35
Driver Version: 6.14.10.7189
Application Path: C:DownloadsSinapse_v0-1.1
Application Codebase: file:///C:/Downloads/Sinapse_v0-1.1/Sinapse.exe
Exception Type: System.TypeInitializationException
Exception Source: Sinapse.Core
Exception Message: The type initializer for 'Sinapse.Core.SinapseWindow' threw an exception.
Exception Target Site: set_Script
Sinapse.Core.SinapseCore.set_Script
Sinapse.Core.SinapseCore.LoadConfig
Nyaooww.... the images look like garbage... wtf?
Here are my specs...
System Information
Time of this report: 6/30/2005, 14:54:15
Machine name: O,o WTF!
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (hmm!~)
Language: English (Regional Setting: English)
System Manufacturer: Generic
System Model: A2H/L
BIOS: Award Medallion BIOS v6.0
Processor: Intel® Pentium® 4 CPU 2.26GHz, ~2.3GHz
Memory: 480MB RAM
Page File: 490MB used, 630MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: SiS M650_651_650_740
Manufacturer: SiS
Chip type: SiS M650 Rev 00
DAC type: Internal
Device Key: EnumPCIVEN_1039&DEV_6325&SUBSYS_16121043&REV_00
Display Memory: 32.0 MB ; I can change it from 16 to 64mb
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: SiSGRV.dll
Driver Version: 6.14.0010.2190 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/4/2003 20:55:00, 1076992 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: sisgrp.sys
Mini VDD Date: 9/4/2003 20:55:00, 400640 bytes
Device Identifier: {D7B71ED9-2065-11CF-7D7B-1836A1C2CB35}
Vendor ID: 0x1039
Device ID: 0x6325
SubSys ID: 0x16121043
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_D ModeMPEG2_C ModeMPEG2_A ModeMPEG1_A
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
System Devices
Name: SiS M650_651_650_740
Device ID: PCIVEN_1039&DEV_6325&SUBSYS_16121043&REV_004&3525EC23&0&0008
Driver: C:WINDOWSSystem32DRIVERSsisgrp.sys, 6.14.0010.2190 (English), 9/4/2003 20:55:00, 400640 bytes
Driver: C:WINDOWSSystem32sisgrv.dll, 6.14.0010.2190 (English), 9/4/2003 20:55:00, 1076992 bytes
Driver: C:WINDOWSSystem32sis650.bin, 9/4/2003 20:54:00, 49152 bytes
Driver: C:WINDOWSSystem32sis740.bin, 9/4/2003 20:54:00, 49152 bytes
Driver: C:WINDOWSSystem32sisgl.dll, 6.14.0010.2190 (English), 9/4/2003 20:54:00, 1857958 bytes
Driver: C:WINDOWSSystem32instFunc.dll, 6.14.0010.2190 (English), 9/4/2003 20:54:00, 5632 bytes
Driver: C:WINDOWSSystem32SiSApCom.dll, 6.14.0010.2190 (Chinese), 9/4/2003 20:54:00, 98304 bytes
Driver: C:WINDOWSSystem32SiSParse.dll, 6.14.0010.2190 (Chinese), 9/4/2003 20:55:00, 221184 bytes
Driver: C:WINDOWSSystem32SiSInst.dll, 6.14.0010.2190 (Chinese), 9/4/2003 20:55:00, 172032 bytes
Driver: C:WINDOWSSystem32DRIVERSsrvkp.sys, 6.14.0010.2190 (English), 9/4/2003 20:57:00, 11008 bytes
Name: SiS Accelerated Graphics Port
Device ID: PCIVEN_1039&DEV_0001&SUBSYS_00000000&REV_003&61AAA01&0&08
Driver: C:WINDOWSSystem32DRIVERSSISAGPX.SYS, 7.02.0000.1150 (English), 9/4/2003 20:55:00, 30720 bytes
System information:
Machine Name: MAGI
OS Version: Microsoft Windows NT 5.1.2600.0 Service Pack 1
Model: A2H/L
Total RAM: 479MB
Processors Count: 1
-Intel® Pentium® 4 CPU 2.26GHz at 2257Mhz
Bios: ASUS - 42302e31
Current Date/Time: 06.30.05 3:00:34 PM
TimeZone: (GMT-06:00) Guadalajara, Mexico City, Monterrey
Device: 0
GDI Name: .DISPLAY1
Display Mode: 1024x768 at 60Hz X8R8G8B8
Revision: 0
SubSystem ID: 16121043
Vendor ID: 1039
WHQL Level: 0
GUID: d7b71ed9-2065-11cf-7d7b-1836a1c2cb35
Driver: SiSGRV.dll
Driver Version: 6.14.10.2190
Of course, I erased some parts o,o
Thanks
  • 3 weeks later...
it dosent work whit vista (avalon)
System information:
Machine Name:
OS Version: Microsoft Windows NT 6.0.5112.0
Manufacturer: TOSHIBA
Model: Satellite A70
Total RAM: 446MB
Processors Count: 1
-Mobile Intel® Pentium® 4 CPU 3.06GHz at 1600Mhz
Current Date/Time: 8/4/2005 12:19:43 PM
TimeZone: (GMT-08:00) Pacific Time (US & Canada); Tijuana
Device: 0
Name: ATI MOBILITY RADEON 9000 IGP Series
GDI Name: .DISPLAY1
Display Mode: 1280x800 at 60Hz X8R8G8B8
Revision: 0
SubSystem ID: ff021179
Vendor ID: 1002
WHQL Level: 0
GUID: d7b71ee2-1b75-11cf-356a-08dfa1c2cb35
Driver: ati2dvag.dll
Driver Version: 6.14.10.6396
Max MultiTexturing: 6
Application Path: D:rkdocksiwu
Application Codebase: file:///D:/rkdock/siwu/Sinapse.exe
Exception Type: System.ArgumentException
Exception Source: System.Drawing
Exception Message: Font 'Monotype Corsiva' cannot be found.
Exception Target Site: CreateFontFamily
System.Drawing.FontFamily.CreateFontFamily
System.Drawing.FontFamily..ctor
