donzee Posted August 29, 2005 Report Share Posted August 29, 2005 File dosen't download correctly >> 3 Ko ?!! u can email me the latest version and i will mirror the link : donzee(at)free.fr thanx Link to comment
SioSae Posted August 30, 2005 Author Report Share Posted August 30, 2005 you can get it here too:http://www.osx-e.com/downloads/dashboard/weather.htmlif it doesn't work eighter i will mail it to you.SioSae Link to comment
Mirror Posted August 30, 2005 Report Share Posted August 30, 2005 Clean and precise. Very nice indeed. Our thanks. Link to comment
petmoi Posted August 30, 2005 Report Share Posted August 30, 2005 Works perfectly! Thank you SioSae for this great widget! =) Link to comment
lostheart Posted August 30, 2005 Report Share Posted August 30, 2005 What I noticed is that when the widget updates itself from say day to night, it won't stay on the spot I want it to be but jumps to a location about a centimeter above...haven't noticed this behaviour in the releases before...Another thing...it's 9 p.m. here in Germany atm and the symbol just changed from sun to moon and back to sun again... Link to comment
SioSae Posted August 31, 2005 Author Report Share Posted August 31, 2005 about the jumping while updating from day to night, i will check if there is anything going wrong.about day/night and the icon: the switch between day and night is made by checking if the weather feed time is between sunset and sunrise time for night, day the opposite. the icons are coming direct from the feed and sometimes the icon is changing after sunset time. i cant affect that.SioSae Link to comment
SioSae Posted September 2, 2005 Author Report Share Posted September 2, 2005 the widget wont update itself by using weather.com feed. fixed that bug. there is a new version available for download. the widget will tell you that after a reload.SioSae Link to comment
Guest BugMeNot123 Posted September 6, 2005 Report Share Posted September 6, 2005 First of great widget just a few niggles when i position the widget where i want it(top left of my desktop) then right click it and click the lock position option but every time i close Konfabulator and restart it or even just close the widget it appears maybe a inch lower then what i left. I would like to suggest a feature if possible, to disable tool tips would be great as i find the annoying. These image indicate my problem i set it where i wanted it in the first pic right clicked and enabled locked position then closed it and reopened it. | Also whenever i start it the update message appears to update to 2.3(hotfix) but i already have 2.3 installed. Link to comment
blulegend Posted September 6, 2005 Report Share Posted September 6, 2005 When using weather.com, the white updating dot sometimes does not go away. Link to comment
gracie34 Posted September 6, 2005 Report Share Posted September 6, 2005 I also have the update message when the widgets starts although I too have 2.3 installed already. If there were some way to turn off the update check this app would be perfect.Thanks so much for all of your hard work on this and widget dock. Fantastic. Link to comment
SioSae Posted September 7, 2005 Author Report Share Posted September 7, 2005 @BugMeNot123about the repositioning, i will take a look. maybe it is because of konfabulator set the position relative to the image positions in the widget or the widget size and there are weather icons (like hail) which are larger and having a lower vOffset like the sun. disabling tooltips is a great idea, will add this feature.@BugMeNot123, gracie34about the update dialog every time you start the widget:- if the update message is shown, there is a new update available. the version you have is v2.3 but there is a new version v2.3 (Hotfix) available. sorry for the confusion about the same version number but i had to do the update really fast because of the weather.com feed wasn't updating correct or wasn't updating at all. so, please download the hotfix version and the update message wont be displayed anymore.disabling the update check will be an option in the next release.@bluelegenddo you have the hotfix version installed? because in v2.3 the weather.com wasn't functioning well (see above)SioSae Link to comment
Guest BugMeNot123 Posted September 7, 2005 Report Share Posted September 7, 2005 Thanks for you reply SioSae i looked at the repositioning again and i closed it then reopened it the update of the weather info was 09:02 i put into position and locked it then when i checked it out again it had moved again and the update time has also changed to 09:42. So it would seem it repositions itself after a refresh whether that be a update of info or by closing it and reopening it.Also about the updated version i tried to get it from http://www.osx-e.com/downloads/dashboard/weather.html but it is the same version that i have i then tried http://www.savefile.com/files.php?fid=2307347 but i could not download it from there for some reason it there any possibilty you could either update http://www.osx-e.com/downloads/dashboard/weather.html to the latest version or supply a new direct download link, thanks for all the help. Link to comment
SioSae Posted September 7, 2005 Author Report Share Posted September 7, 2005 i'm sorry osx isn't updating the last version. maybe i will have to upload a new 2.4 for osx update it. savefile is working for me but maybe i have to find another place for the widget, if anybody can host it for me or can tell me where i can put it online that would be very nice.about the positioning: the widget will be shown after an update the way that the weather icon image is shown completelly. if the image is covered from the top screen border, the widget will move down. you cant see where the sun image will end for instance because its opacity is near 0 on its borders. i have to take a look how i can optimize it a little bit.SioSae Link to comment
gracie34 Posted September 7, 2005 Report Share Posted September 7, 2005 Thanks SioSae for you reply, I got 2.3 from osx-e also thinking it was the latest version because it downloaded faster than savefile for me (I'm, on dialup). I think I will just wait for the next full version since that's the only problem I'm having.Thanks again! Link to comment
EfreetiRiztak Posted September 10, 2005 Report Share Posted September 10, 2005 Hello there SioSae,Here there, great work on this widget. One of my favorites so far. Anyway, I have a quick request. I notice that after I suspend my computer and then come back to it, it takes a while for the weather to update itself. Is there any way that you can make it so that it updates automatically upon reconnection (without having to click the white circle)?Thanks,Asim Link to comment
aashish13 Posted September 10, 2005 Report Share Posted September 10, 2005 maybe you should try deviantart.com. Great work btw (Y) Link to comment
blulegend Posted September 11, 2005 Report Share Posted September 11, 2005 Sometimes the update now button doesn't really update either. Changing the weather source will sort of fix it until it happens again. Not sure if it's important, but I usually don't shut down my laptop but hibernate it. With past versions the widget did not update for a long time after resuming from hibernation, not sure if it updates soon after resuming with the latest version though. I'm using the latest hotfix. Sometimes the updating dot does not go away after updating. Link to comment
luizjb Posted November 13, 2005 Report Share Posted November 13, 2005 Very nice widget but I only have updates when I restart the program...the automatic updates don't work and the update now button either...it's a pitty Looking in more details I figured out that that problem only happens with weatherchannel.com forecast. Accuweather works fine! Link to comment
ron21 Posted November 13, 2005 Report Share Posted November 13, 2005 hey, What ever happened to version 2.4? Link to comment
Ghostwalker Posted November 13, 2005 Report Share Posted November 13, 2005 SioSae if you need a place to host it I will put it on my server just send it to me when your ready and I will send you the link. Link to comment
SioSae Posted November 14, 2005 Author Report Share Posted November 14, 2005 2.4 in in the works, thank you ghostwalker, still needing a place for hosting it and i will send it to you if its finished. Link to comment
Netmaster4 Posted November 18, 2005 Report Share Posted November 18, 2005 @DrEaMs In DiGiTaL & goforI will try to fix the bug and add an option to completely hide the close box today. thanks for posting the bug. As far as I can see it wont be a problem to solve this @jpgodlew the new version I uploaded yesterday fix this bug. download it and it's fine. SioSae Can I take it for a commercial homepage ? Link to comment
CriplingDream Posted November 18, 2005 Report Share Posted November 18, 2005 2.4 in in the works, thank you ghostwalker, still needing a place for hosting it and i will send it to you if its finished.i can host it for you @Paperdoll.be, just mail me. Link to comment
luizjb Posted November 26, 2005 Report Share Posted November 26, 2005 Just one thing that I don't know if it is a bug or not. Every update on this widget freezes my computer. I can't do anything in that time (maybe 10 seconds). Since the widget is frequently being updated, that is really a problem to me. I love this widget and I don't want to change it One possibility could be to have the option of changing the update frequence. That would be nice to me. I'm running on Windows XP SP2. Thank you, can't wait for the dashboardweather update !!! Link to comment
ToddJ Posted November 1, 2006 Report Share Posted November 1, 2006 mine updates very slowly....has there been a new version of this widget yet? Link to comment
