[Help] WindowBlinds Problems
Okay pals, first of all, I'm back. But I come with this little problem:
Here's the link to the image
Now, Im quite curious how to fix this, because I cant see half of the things. And I can't even add things on "Per Application" because I cant see the dammed buttons.
I remember there was a sollution to this, but I cant recall wich.
Thanks
EDIT:
Sorry about that ~_~
__________________________________
Next time i`ll just delete the image
/Post edited
Unbeliever
Hmmm ... it's happened to me earlier, but it was never quite as bad as this - at times I could see the buttons for per application settings partly cut off.
Restoring to the default font and the normal size of the font that came with the skin followed by a reboot usually solved the problem for me. Try that and see if it helps - if it doesn't, I'm outta ideas too :(
