Unbeliever Posted June 22, 2005 Report Share Posted June 22, 2005 Actually I think it has to do with avedesk, because I don't have multiplugin (yet) and when I play a song with iTunes open (not minimized to tray) and then exit and restart Avedesk, and then try to minimize iTunes, sometimes it doesn't minimize and I may have to exit Avedesk or iTunes to get it to work again.I don`t think you understand my prob. It`s not a functional bug, everything works. It`s an annoying visual bug that i have each time i minimize iTunes. Link to comment
buddyd16 Posted June 22, 2005 Report Share Posted June 22, 2005 great release localhost one issue Im having is the media button functionality isn't working the previous multiplugin worked great with my media keys but doesn't in this verison.I have a Dell Inspiron 9300 with windows xp pro sp2 Link to comment
thekingart Posted June 22, 2005 Report Share Posted June 22, 2005 I, too, am unable to see where the foobar2000 passthrough function is.Any help? Link to comment
MikelxCore Posted June 23, 2005 Report Share Posted June 23, 2005 Wow, I love you. And yes, there is a noticable difference between the iTunes output and the Foobar2000 output. I prefer Foobar2000. Thanks. Link to comment
applelover Posted June 23, 2005 Report Share Posted June 23, 2005 Also wondering where the foobar200 passthrough function is.Otherwise, another superlative effort as always. Link to comment
Nico Posted June 23, 2005 Report Share Posted June 23, 2005 Ok, I accidentally removed the menu and I dunno how to get it back and using the Alt + Down keys doesn't work for me. Link to comment
nightcrawler1089 Posted June 23, 2005 Report Share Posted June 23, 2005 @Nico-- Ctrl + , (comma) will show the iTunes preferences. There's a multi-plugin tab. I think you can figure out the rest . -NC Link to comment
FatAxl Posted June 23, 2005 Report Share Posted June 23, 2005 I was also wondering hot to use Foobar passthrough ?? I downloaded and installed Foobar for this function, and can't figure it out. I appreciate any help !!!FatAxl Link to comment
scheming Posted June 23, 2005 Report Share Posted June 23, 2005 im an idiot but umm i checked off to have the file menu bar removed now i dont know how to get it back or get to it... any ideas? Link to comment
aquaraven Posted June 23, 2005 Report Share Posted June 23, 2005 You are a GOD!!! Thanks so much:D Link to comment
dkordik Posted June 23, 2005 Report Share Posted June 23, 2005 Since it goes through foobar why aren't we able to take advantage of foobar's gapless playback? Link to comment
view Posted June 23, 2005 Report Share Posted June 23, 2005 i can't download it could you make a mirror or send it to me view.aqua@gmail.com Link to comment
duyvan82 Posted June 23, 2005 Report Share Posted June 23, 2005 Thanks for the plugin, I'm just loving it :D. For those of you who have problems with localhost's link, you can grab the plugin here (use right click and save as) Mplugin Link to comment
gofor Posted June 23, 2005 Report Share Posted June 23, 2005 Great work!and i overheard iTunes 4.9 is coming soon Link to comment
view Posted June 23, 2005 Report Share Posted June 23, 2005 Thanks for the plugin, I'm just loving it :D.For those of you who have problems with localhost's link, you can grab the plugin here (use right click and save as) Mplugin Thanks! Link to comment
tetmin Posted June 23, 2005 Report Share Posted June 23, 2005 If anyone who has the passthrough working could please post an answer to this, that would be great. I've got foobar installed and have tried installing and uninstalling Mplugin, but i can't see the foobar setting anywhere?Thanks Link to comment
iGo Posted June 23, 2005 Report Share Posted June 23, 2005 Please read the instruction when you select Foobar Option from MPlugin setting... apparently you have to make changes in QuickTime settings to get Foobar Passtrough work.Note if you have installed QuickTime 7 preview for window. In the Audio tab from QuickTimes Control Panel, select Safe Mode (WaveOut only). Link to comment
drudragon Posted June 23, 2005 Report Share Posted June 23, 2005 I got it working, fantastic stuff , didn't think that itunes quality was so poor compared to Foobar :/ Link to comment
capitalq Posted June 23, 2005 Report Share Posted June 23, 2005 My Multi-Plugin options menu has been a bit..funky since M-P 0.5, as you can see here:http://www.sitesled.com/members/freddiemercury/iTunes.jpgAny reason why? Operating system is Windows XP SP2. My only concern is that I can't see the foobar option. Link to comment
jggame Posted June 23, 2005 Report Share Posted June 23, 2005 Please read the instruction when you select Foobar Option from MPlugin setting... apparently you have to make changes in QuickTime settings to get Foobar Passtrough work.Note if you have installed QuickTime 7 preview for window. In the Audio tab from QuickTimes Control Panel, select Safe Mode (WaveOut only).??? the problem is, the installer never provided me a check dialog or a single one reference to foobar and it didn´t install a plugin in foobar folder, anyway the defaut itunes quality is ok. Link to comment
mntnbkr1065 Posted June 23, 2005 Report Share Posted June 23, 2005 thanks for including my skin as the default Link to comment
mknoffler Posted June 23, 2005 Report Share Posted June 23, 2005 I actually think the Foobar thing is there, its just that the window is too small to show it. On my home computer it truncates before the option to disable the scripting interface and on my computer at work it shows that option and then truncates.If you click on the last box showing it will uncheck it (or check it), but hit the space bar and it will re-check the box. Then you can scroll down with the arrow keys and select boxes using the space bar. That being said, I don't know how many more menus there might be or where the foobar one shows up, so hopefully someone can clarify that... otherwise, its hunt and peck. Link to comment
capitalq Posted June 23, 2005 Report Share Posted June 23, 2005 Got the Foobar plugin working, and it sounds great for the stuff it can play. Which is basically WAV, AAC and MP3. Unfortuantely, it's not compatible with Apple Lossless format, CDs, or (obviously) purchased iTunes music. For the AAC I have, it sounds loads better than iTunes. Unfortuantely, around 75% of my 4,201 songs are encoded in lossless, and therefore, I have to use iTunes' audio. But it's Foobar's fault for not making an Apple Lossless plugin, isn't it?The menu is, from the Winamp option down (hopefully no one needs higher):-Make programs recognize iTunes as Winamp-Fix the functionality of Media Keys-Don't create Unknown Album folders-Suppress the scripting warning message-Foobar2000 passthroughSo, yeah, just keep tabbing down to the option you want and press space bar. Link to comment
mknoffler Posted June 23, 2005 Report Share Posted June 23, 2005 Actually, with a little more playing, I figured out that if you select the 'Hide Menu' option, hit the space bar to reapply your old setting from before you clicked it, and then scroll down once and hit the space bar you'll get it. Now I have a Foobar Error that says no user interface found. Any thoughts? Link to comment
capitalq Posted June 23, 2005 Report Share Posted June 23, 2005 Read the first message of this topic again. Foobar2000 won't run with the option enabled, whether iTunes is open or closed. Link to comment
