UNI0N Jack Posted August 2, 2005 Report Share Posted August 2, 2005 Sarcasm doesn't contribute anything to this widget or this thread. No need to be an ass about something you don't think is a good idea. Link to comment
userx Posted August 2, 2005 Report Share Posted August 2, 2005 Hi, I don't have any old ver. of the WidgetDock.config file. I just got 2.5. How do I configure it? I did read the help file... Thanks! Great Work, BTW Link to comment
XanthraX Posted August 3, 2005 Report Share Posted August 3, 2005 I just downloaded the version 2.5. I read the readme file, but I am not sure how can I add programs or folders, because I can add only *.kon and *.widget files. Where I'm wrong? Link to comment
Ghostwalker Posted August 3, 2005 Report Share Posted August 3, 2005 @ UNI0N Jack: My apologies @ userx: When you first run it will ask for a config file you will have to use the default config file which is in the widget dock folder.@ XanthraX: At the bottom where it says add widgets there is an up/down arror next to that click it and it will say add program click it again add folder and so on. At the top you have the same thing sort by name click the arrows and sort by type. Link to comment
Aworldapart Posted August 3, 2005 Report Share Posted August 3, 2005 Hi siosae, sorry to bother ya here ...but i've been experiencing some problems with widget spawning since i upgraded to 2.5... here take a look:http://img243.imageshack.us/img243/8194/untitled15ts.jpg Please look at daily dose (thats the comic widget on the left hand side). It appears as though the widget is in normal view but when i get out of konspose to see normal view it isn't there. This has happened to me with other widgets as well ... dictionary and stickies for example. I tried turning off dashboard dock and then openning the widgets and discovered that the problem was still there. I had to turn konfab off all together and then turn on the widget and it was fine. But when i used dash dock ..it started to happen again. Also I've installed the widget as you have laid out. Do you have any idea whats the problem here???? Thanks for your help Link to comment
PDidee Posted August 3, 2005 Report Share Posted August 3, 2005 Siosae is aware of that problem. He says it's a Konfab 2.1 problem. He's working on it. I read it a bit earlier in this forum I think.Edit: Yep I thought I read it before It's in response to S@M having the same problem. Post #'s 195 & 196. Link to comment
Ghostwalker Posted August 3, 2005 Report Share Posted August 3, 2005 SioSae is on vacation right now and yes it is a konfab problem should be fixed with konfab 2.1.1 Link to comment
Aworldapart Posted August 3, 2005 Report Share Posted August 3, 2005 thanks so much guys ...i looked over the thread but prolly a bit too quickly ..i missed those posts! Thank you very much pid and ghost !! Link to comment
SioSae Posted August 22, 2005 Author Report Share Posted August 22, 2005 Hello again!I'm back from holiday and ready to empty my full list of changes for the next release.SioSae Link to comment
matthew Posted August 22, 2005 Report Share Posted August 22, 2005 hey thats cool, lookin forward for the next release Link to comment
Ghostwalker Posted August 22, 2005 Report Share Posted August 22, 2005 SioSae hope you enjoyed your vacation but I will say glad to see your back. Link to comment
SioSae Posted August 22, 2005 Author Report Share Posted August 22, 2005 @ghostwalkerthanks, and it was great. needed the break to reload my batteries ;-) because of having my mails stored on my home pc i will answer your mail next weekend. Link to comment
Larsen2k4 Posted August 22, 2005 Report Share Posted August 22, 2005 Welcome back man Link to comment
SioSae Posted August 25, 2005 Author Report Share Posted August 25, 2005 here is a little update whats finished for the next release so far:- you can set a custom default icon - click on an already opened widget will close it instead of reload it- added some more tooltips- you can load different configuration files- you can automatically load all widgets from a specified directory (and it will only add new widgets to the dock)- all icons will be shown in correct scale (no stretching anymore, so little yoda looks fine now ;-))still working on the resizing of the dock for the next release...EDIT:on the fly resizing of the dock is finished.SioSae Link to comment
firecracker6 Posted August 25, 2005 Report Share Posted August 25, 2005 wonderful news... great work SioSae A question; could you explain to us the versioning between the WidgetDock released for the Konfab Widget community, and the Dashboard flavor? Is one a branch of the other? Are they both feature inclusive? Thanks in advanc Link to comment
ataleser Posted August 26, 2005 Report Share Posted August 26, 2005 that's very nice. good news. Link to comment
SioSae Posted August 26, 2005 Author Report Share Posted August 26, 2005 @firecracker6new version is coming today. about the differences between the WidgetDock and the WidgetDockMod: they will have the same features from this release date on and i consider to let the WidgetDockMod have the same version number like the original WidgetDock which would be v2.6 to wipe out all missunderstandings. Right now the WidgetDockMod doesn't support Programs and Directories to be add but for the new release they will have the same programming sources. The WidgetDockMod started as a branch of the WidgetDock some time ago and got a version number started from v1.0 althrough the WidgetDock version was v2.3 at that time. to minimize my effort and make a future skinnable version possible i had to put them together now. SioSae Link to comment
SioSae Posted August 26, 2005 Author Report Share Posted August 26, 2005 hi there,here you can get the new widgetdock version: LINKi will update it on osx-e.com and the widgetdockmod in the widgetgallery if there aren't bugs inside so if you could test it a little bit, that would be very nice.thanks,SioSae Link to comment
firecracker6 Posted August 26, 2005 Report Share Posted August 26, 2005 Hi SioSae,just finished reading the "readme.txt" file, had a few questions:If i have your widgetdockmodv1.1 installed from Konfab's widget gallery, can i still upgrade using your included instructions to Widgetdockv2.6? For instance, keeping my current config file, etc.well, that's about it actually,Thanks Link to comment
SioSae Posted August 26, 2005 Author Report Share Posted August 26, 2005 yes you can, or you can wait until i update the widgetdockmod from 1.1 to 2.6 on the widgetgallery in a few minutes. it will have all the features this release have.SioSae Link to comment
firecracker6 Posted August 26, 2005 Report Share Posted August 26, 2005 Thanks, I'll waite, so it's the update to the widget gallery that instantaneous, or will there be a week eval period? Link to comment
SioSae Posted August 26, 2005 Author Report Share Posted August 26, 2005 i dont know, we will see but until then i will put direct links on the first post.SioSae Link to comment
firecracker6 Posted August 27, 2005 Report Share Posted August 27, 2005 I just finished testing out both the WidgetDock and WidgetDockMod v2.6. I have an instance of the WidgetDock crashing and taking with it, Konfabulator.exe; these are the steps to experience this.Installation/update of WidgetDockModv1.1 to WidgetDockModv2.6. I unzipped WidgetDockMod2.6.zip to the same folder as my current WidgetDockMod folder, and copied my previous icons and WidgetDock.config file over to the WidgetDockMod2.6 folder. I shutdown/closed WidgetDockModv1.1 and launched v2.6 pointing the 1st dialog to the proper config file.The dock appears, i click on a widget, I hear all these 'konfab clicking' sounds (you know, when widgets are closing down.) The dock disappears and takes Konfabulator with it. Re-launching the dock and clicking on another widget causes the same crash. Clicking on an .exe (program) shortcut does the same thing. Do you have any suggestions? Thanks in advance.EDIT: I just replaced my personalized config file with the original one (empty) that comes with the "WidgetDock2.6.zip" file and went into "Manage Widgets" and added a widget, (The Dashboard Calculator) and assigned an Icon, etc.. when I went to click on the newly added widget in the dock, the dock and konfab shutdown immediately upon clicking the icon. Odd.. it never did this in the prior versions. Link to comment
ron21 Posted August 27, 2005 Report Share Posted August 27, 2005 I keep getting this error : "WidgetDock2.6 was unable to load itself sucessfully" Link to comment
kolouker Posted August 27, 2005 Report Share Posted August 27, 2005 I don't know if it is a bug, but the 2.6 version keeps closing my konfabulator after adding a widget, it happens in konspose mode, haven't tried in other modes. With WD 2.5 everything works ok. Link to comment
