tommytom02 Posted December 18, 2005 Report Share Posted December 18, 2005 i'm having a problem when I try to run widgets from the dock (dock v. 2.9 and widget engine ver. 3.0.1): it just does nothing at all. i even tried to run them all to confirrm running a widget not made by Yahoo widgets but no luck. is this just me and/oor wil it be fixed in the next dock version? (it runs apps and folders fine):edit:nevermind, i just had to change the checkboxes on the widgets to the cascade looking thing (sry, dont know what thats called) and i never had to do that before Link to comment
SioSae Posted December 19, 2005 Author Report Share Posted December 19, 2005 does it mean, only the spawn mode (more instances of widgets enabled aka the cascading looking checkbox thing ;-) is working? if so i have to fix that. by the way, there is a little delay on releasing the new 3.0 version. its pre christmas time ;-)there is a widget engine version 3.0.1? thought it was 3.0, maybe thats why it isn't working. i will have a closer look.SioSae Link to comment
tommytom02 Posted December 19, 2005 Report Share Posted December 19, 2005 yes, only spawn mode is working. thanks for your work on this widget, btw, it's definitely the most useful of all the widgets available. oh and now it's 3.0.2 Link to comment
SioSae Posted December 22, 2005 Author Report Share Posted December 22, 2005 There is a new version online fixing the reported bug. Start single instance widgets should work now. SioSaeplease let me know, if its working. thanks a lot Link to comment
tommytom02 Posted December 24, 2005 Report Share Posted December 24, 2005 works great, thanks a lot Link to comment
grim53 Posted December 30, 2005 Report Share Posted December 30, 2005 i have no idea what spawning mode is, but im having a problem of nothing opening up in the widget dock. and it has worked with the older versions, i think the yahoo 3.0 thing broke it :/ Link to comment
SioSae Posted December 31, 2005 Author Report Share Posted December 31, 2005 spawning mode means, that the dock will handle multiple instances of one widget. there are three states of the checkbox in the manager (for widgets), unchecked, checked and multichecked. checked means, it open and reopen the widget if you cklick on its icon twice. multicheck will open another instance of the widget if you will cklick it twice.there was a problem with the widget v2.9. could you please verify if you have the newest version (v2.9a)? Link to comment
ezgo2u4u Posted January 10, 2006 Report Share Posted January 10, 2006 What a great job you did! I love it. Link to comment
garri2422 Posted January 18, 2006 Report Share Posted January 18, 2006 hi folks i'm trying out the dock and it is good, i just have one question, how do i change icons of the widgets on the dock, they're all like default icons, how do i use the icons that was provided... i hope this is not a stupid question but all the posts here have been concerned about the performance, all i want is to see the right icons and not the default icons on my dock LOLthank you for those who will reply Link to comment
SioSae Posted January 18, 2006 Author Report Share Posted January 18, 2006 @ezgo2u4uthanks a lot.@garri2422you can modify the widgets by clicking the icons in the widget manager, it will open a file dialog where you can choose another icon.the manager works this way, click the checkbox (change state), icon (set new icon), name (change display name) or delete button to customize the dock.SioSae Link to comment
laximus Posted January 18, 2006 Report Share Posted January 18, 2006 Hi, SIOSAE!Its Laszlo from Hungary!I have a little problem, maybe you can help me.I have your WidgetDock27, and I use this with the original Konfabulator program.When the YahooWidgetEngine released, I installed it, but the widget dock27 doesnt work correctly with this engine: I can spawn only two pieces, and when I click the cross, the animation is sliced, I mean very low quality..(Hope you understand.) After I installed the WidgetDock29, but the two problems are still the same. If I uninstall the YahooWidgetEngine, install Konfabulator, the Widget Dock 27 works great, but this way I cannot use the new widgets from Yahoo. Do you have any idea? Maybe the problem is the YahooWidgetEngine? Thank you taking time to me! Laszlo Link to comment
SioSae Posted January 19, 2006 Author Report Share Posted January 19, 2006 do you using the Yahoo Widgets Engine version 3.0.2 and WidgetDock 2.9a?ant what system you are running at (mac or win)? i cant run and test it on a mac. they (konfab crew) only make it availabe for windows in the widgetgallery the last versions. i dont know why, maybe it causes some problems, but everytime i'm asking in the gallerys comments or in the forum, i didn't get an answer. what do you mean by low quality? could you please explain it a little more?SioSae Link to comment
laximus Posted January 19, 2006 Report Share Posted January 19, 2006 Well, now Im using the Konfabulator and WidgetDock2.7, but of course I tried the Y.W.E.3.0.2 with WidgetDock 2.9a , and at this time were the problems what I wrote. (Sorry, if my english is not the best, Im from Hungary.) I have Windows Xp Pro. Pentium 4, 2,4GHz. Radeon 9550. With the original Konfabulator the W.D2.7 works perfectly. About the animation of WidgetDock2.9a on my PC: low performance means its not smooth but jumpy a little, when I open the dock. Actually, dont working well the WD2.7 and dont the W.D2.9a too in the YahooWidgetEngine 3.0.2 and I can spawning widgets only two pieces and not more.Well, as I read here, and in other forums, there are many problems and critics with the new YahooWidgetEngine. They have nice widgets, like YahooContacts , but it doesnt work with the Konfabulator. (What is strange for me.)Well, hope you have a solution for these problems, till I will use the good old version of Konfabulator and your very nice WidgetDock2.7. Thanks.Laximus Link to comment
SioSae Posted January 19, 2006 Author Report Share Posted January 19, 2006 could you please check if your system "knows" the tasklist command by open a command line window (cmd.exe) and type in "tasklist" without the quotes and execute. if the command doesn't work or is unknown, than spawning widgets wont work.About the animation, hm, i have to think about that.SioSae Link to comment
halfpint Posted January 22, 2006 Report Share Posted January 22, 2006 This is great! Only one thing, when I bring up the manage widgets window and then select a widget's icon to assign it a new one, the Open Window for the icon selection is behind the Manage Widget window. I have to go to the Widget preference Window and select "Normal" in the "Level of Window" field (Even if it is already selected) and then click okay. The open window for the Widget icon selection is then on top.P.S. I am running Konfabulator/Yahoo! Widget Engine 3.0.2 (Build 79)(This was posted first on the Konfabulator Widget Gallery...) Link to comment
SioSae Posted January 26, 2006 Author Report Share Posted January 26, 2006 i will fix this in the next release Link to comment
ZackaruS Posted January 30, 2006 Report Share Posted January 30, 2006 I change a little thing in my translation.[ATTACH]7007[/ATTACH] Link to comment
SioSae Posted February 1, 2006 Author Report Share Posted February 1, 2006 thank you zackarus, i will add it to the next releaseSioSae Link to comment
Sheets Posted February 6, 2006 Report Share Posted February 6, 2006 This is great...and you know what would be a great addition to it is the drag and drop feature of mac's dashboard Link to comment
SioSae Posted February 6, 2006 Author Report Share Posted February 6, 2006 you mean drag&drop a widget from the dock to the screen (with the morphing and positioning)? yeah, that would be cool but cant be done right now because there is no interface where i can communicate with a widget (for setting its position). of course there is the tellwidget thing but that would mean every widget has to implement something... as soon as they will give us some kind of widget interface (via com or whatever) i will implement it.SioSaebtw, this week i will release a v3.0 version with some fixes and minor new features. Link to comment
Ghostwalker Posted February 6, 2006 Report Share Posted February 6, 2006 btw, this week i will release a v3.0 version with some fixes and minor new features.always love it when you do that Link to comment
SioSae Posted February 8, 2006 Author Report Share Posted February 8, 2006 always love it when you do thatwanted to do this (and more) for some time now but being so busy the last months. i still have this idea about a new widget too...SioSae Link to comment
SpyGamer Posted February 9, 2006 Report Share Posted February 9, 2006 Can't wait Keep doing this awesome work. Congratulations Link to comment
thisisfreaky Posted February 15, 2006 Report Share Posted February 15, 2006 great widget, just isnt like the mac's dock Link to comment
godwasdead Posted February 22, 2006 Report Share Posted February 22, 2006 Excellent work!!!!! Link to comment
