SioSae Posted February 22, 2006 Author Report Share Posted February 22, 2006 thanks to all of you.@thisisfreakywhere are the differences? (besides the drag and drop of widgets to the desktop with this nice morphing effect and of course all the features my widget has and the original dock hasn't ;-))wanted to make a big new release but releasing a v2.9b instead.will have the following changes:- fixed a bug on closing the widget manager while its icon is shown in the dock- fixed a bug when select new location of lost items- fixed a bug preventing the widget from loading/working on a mac- changed tooltips on the items, showing the items name too now- new context menu entry: "hide widget manager icon" will directly open the manager window by clicking on the "manage widgets..." button (and of course hide the icon for the widget manager)- new context menu entry: "set wheel opacity..." to change the opacity for the wheel button only- new language: french (and hopefully danish too)- enabled the use of Application Icons again (in the context menu "Using Program Icons")- fixed a bug in the drag&drop featurethats it so far.any suggestions if i missed something important are welcome.SioSae Link to comment
thisisfreaky Posted February 26, 2006 Report Share Posted February 26, 2006 oh, im sorry i didnt even know that you made a widgetdock--i was thinkin of dockmod anyway, could u also start on a macosx like dock...that would be GREAT Link to comment
SioSae Posted March 1, 2006 Author Report Share Posted March 1, 2006 new version v2.9b is available. Link to comment
SioSae Posted March 1, 2006 Author Report Share Posted March 1, 2006 please redownload, fixed a bug on adding new widgets (missing icon)thanks Link to comment
sercotec Posted March 1, 2006 Report Share Posted March 1, 2006 Where is the download link on the website ? I see no buttons Link to comment
SioSae Posted March 1, 2006 Author Report Share Posted March 1, 2006 link: v2.9b (there you have to click for the download link)sorry for that, it isn't as clear as a download button would be. Link to comment
sercotec Posted March 1, 2006 Report Share Posted March 1, 2006 Thanks, I had already extracted links from source code Good work, thank you Link to comment
ZackaruS Posted March 2, 2006 Report Share Posted March 2, 2006 It does not want to launch out at home. I have this: "WidgetDock2.9b was unable to load itself successfully." For SioSae: I see inside, why 'french.js' isn't inside? Link to comment
SioSae Posted March 2, 2006 Author Report Share Posted March 2, 2006 because i didn't got the translation of the new strings in time. sorry, had to finish yesterday. but i will get a danish translation today and if i get your french one too i will release a revised v2.9b with the two additional languages.did you try to download it again and give it another try?SioSae Link to comment
ZackaruS Posted March 2, 2006 Report Share Posted March 2, 2006 Where the widget's preferences are physically locate? I think my problem comes from here. Link to comment
SioSae Posted March 2, 2006 Author Report Share Posted March 2, 2006 documents & settings//local settings/application data/yahoo/widget engine/... Link to comment
ZackaruS Posted March 2, 2006 Report Share Posted March 2, 2006 thank SioSae. I remove all WidgetDock folder and my problem is still there.I will find the solution. Link to comment
ZackaruS Posted March 2, 2006 Report Share Posted March 2, 2006 Ok I found. I put WidgetDock in debug mode. I saw:"[WidgetDock] TypeError: Languages[preferences.language.value] has no properties (localization.js: Line 58)onLoad failed. Most likely an exception was encountered."I write "include("french.js");" in 'localization.js' and I include 'french.js'.Finally, WidgetDock work. The problem was that the language used in 2.9a was french. As it was not included in the new version, the widget created an error.Thus the preferences are not saved in "documents & settings//local settings/application data/yahoo/widget engine/...". Maybe in the Windows registry. Link to comment
SioSae Posted March 2, 2006 Author Report Share Posted March 2, 2006 yes, maybe there too. and maybe this error wouldn't occur if you didn't change the name of the widget file itself (from widgetdock2.9b.widget to widgetdock.widget i suppose). i give the widget file a new name every time i release a new version because of possibly occuring problems with earier versions. i have to think about a mechanism to prevent such things from happening.thanks for your investigation.SioSae Link to comment
ZackaruS Posted March 2, 2006 Report Share Posted March 2, 2006 When I create the 'french.js', I have rename the widget in 'WidgetDock2.9b. widget'. I have do that to differentiate them. I thought that you were going to pass from 2.9a to 3.0. Link to comment
SioSae Posted March 2, 2006 Author Report Share Posted March 2, 2006 because i couldn't finish the implementation of the features i wanted to have in the 3.0 release i decided to make a 2.9b instead, giving me time to finish my work for the next "big" ;-) release. Link to comment
ZackaruS Posted March 4, 2006 Report Share Posted March 4, 2006 Hello,I have finished the translation of 'readme.txt' and the new items in 'french.js'. I included them in WidgetDock and WidgetDockMod. I have make a small modification in ' WidgetDock.kon' (I included the icon in the security dialog).WidgetDock v2.9b / WidgetDockMod v2.9bI would like to know if the addition of the french language helped or not. I do not know if there is french community in this forum.Oh yes. I know where the values of the preferences are saved. In the Windows registry, [HKEY_CURRENT_USERSoftwareYahooWidgetEngineWidgets]. Link to comment
Slewed Posted March 10, 2006 Report Share Posted March 10, 2006 This is really quite amazing, in fact i downloaded yahoo widget engine and this is the only widget i'm running off it (i know, its a WIDGETdock and you're supposed to use the widgets).one small request: i use rklauncher, which has an always on top setting. is there a possibility to make this dock expand on top of rklauncher, because otherwise it gets in the way (and i dont want to autohide it, and i need it on top of other windows) Link to comment
alduleimi Posted April 19, 2006 Report Share Posted April 19, 2006 Hi SioSae, i downloaded Yahoo! widgets on my new mac machine (with intel processor) and all widgets working apaprt when i am trying to launch widgetdock suddenly the whol Yahoo! widget program stop responding and i have to do force quit.I assume it's something to do with compatiblity for this widget with new mac (universal) am i the only one having this problem ? and are you planning to launch new updates that include fix for this bug ?thanksalduleimi Link to comment
firecracker6 Posted April 20, 2006 Report Share Posted April 20, 2006 just wanted to add my respects and +1 for an update to your amazing widget... In my opinion, one of the most add-value widgets that provides my only incentive to installing the yahoo widget engine. I'm crossing my fingers for an update with that SioSae skill Link to comment
pat_ty Posted April 28, 2006 Report Share Posted April 28, 2006 Hi SioSae,I play with your widget. I really love it. However, I have one question. Is there any way to fix the position of the wheel? I want it to lock at the same position after I close the dock. Link to comment
racorrea Posted May 15, 2006 Report Share Posted May 15, 2006 i have a problem, i set the wheel opacity to 0% but now i cant use the widget dock i tried to open it again, redownload it, but nothing works, any advice? hope some one could help me Link to comment
ZackaruS Posted May 15, 2006 Report Share Posted May 15, 2006 Go in the Windows registry, exactly in [HKEY_CURRENT_USERSoftwareYahooWidgetEngineWidgetsWidgetDock2.9b], and change the value of "crossOpacity" (0 -> 255). Link to comment
SioSae Posted June 27, 2006 Author Report Share Posted June 27, 2006 Hi there,had a long timeout, but being back again to "finish" my widgetdock ;-) Link to comment
