Timan Posted August 3, 2005 Report Share Posted August 3, 2005 Aqua-Softs IRC room is finally open.irc.stardock.com #aquasoftThanks to Frogboy (www.stardock.com) for setting us up. Feel free to idle in there and whatever you guys do in an irc room. Same rules on the forum apply there, also check out these rules that neowin has for their irc channel, basically same rules apply in our channel. http://www.neowin.net/ircrules.htmAnyway see you guys there, have fun whatever, this is meant to replace the shoutbox. It was broke in the upgrade to vb3.0.8 and will most likely not return to the forums. Link to comment
Jon@z Posted August 3, 2005 Report Share Posted August 3, 2005 wohooooo:D thanks timmeh and Frogboy.... see ya'll there Link to comment
sean.fletcher Posted August 3, 2005 Report Share Posted August 3, 2005 How do I use it? when I click on it, it says "irc is not a registered protocol" Link to comment
applelover Posted August 3, 2005 Report Share Posted August 3, 2005 How do I use it? when I click on it, it says "irc is not a registered protocol"You need an IRC client.Several are available, depending on the platform you are running.I happen to use XChat. Link to comment
AthleticTrainer1981 Posted August 4, 2005 Report Share Posted August 4, 2005 any chance you are looking for some help with the irc room? Link to comment
shmengie Posted August 4, 2005 Report Share Posted August 4, 2005 hey. so i've got the channel config'd and connected via trillian. i also get the protocol error. what do i do? Link to comment
Ellada Posted August 4, 2005 Report Share Posted August 4, 2005 Works with mIRC. What are some good IRC clients for osx? I'm on a PC by force. Luckily it had a irc client on it already. i'm getting used to IE and big blue close, max, min buttons. Link to comment
kaloyster Posted August 4, 2005 Report Share Posted August 4, 2005 ataleser kamusta ka man! Link to comment
Tobbz Posted August 4, 2005 Report Share Posted August 4, 2005 Works with mIRC. What are some good IRC clients for osx? I'm on a PC by force. Luckily it had a irc client on it already. i'm getting used to IE and big blue close, max, min buttons. Try Colloquy: http://colloquy.info/ :-) I really like.. It customizable like AdiumX Link to comment
idunno22 Posted August 4, 2005 Report Share Posted August 4, 2005 too bad not on EFnet Link to comment
ultraman Posted August 4, 2005 Report Share Posted August 4, 2005 Thanx, I'll be there if I have time Link to comment
Derelikt Posted August 5, 2005 Report Share Posted August 5, 2005 Works great with Colloquy Link to comment
AndreasV Posted August 9, 2005 Report Share Posted August 9, 2005 Hey, why nobody there? Link to comment
Timan Posted August 9, 2005 Author Report Share Posted August 9, 2005 Like everything else on this site, people never use what they want. Link to comment
Ivan Posted August 9, 2005 Report Share Posted August 9, 2005 thanks for killing the shoutbox, even if it was accidental. Link to comment
Church Punk Posted August 14, 2005 Report Share Posted August 14, 2005 cant join to the channel, using trillian mIRC but i dont know how to join Link to comment
kavin Posted August 14, 2005 Report Share Posted August 14, 2005 i use it both on bersirc and Opera 8.02. D cant find enough aqua-softers there. @churchpunk , join by entering server name : irc.stardock.com and type in "/join #aquasoft" (without quotes ) Link to comment
Church Punk Posted August 21, 2005 Report Share Posted August 21, 2005 thnx man i already try it but no1 there... Link to comment
Tromoly4130 Posted August 22, 2005 Report Share Posted August 22, 2005 I'm using Miranda and am very confused of what server to use to get to the channel. Any ideas? Link to comment
Tromoly4130 Posted August 25, 2005 Report Share Posted August 25, 2005 I looked through every server in Miranda and irc.stardock.com isn't listed. Could it be that my version of Miranda is screwed up or that it simply isn't listed? Link to comment
Ivan Posted August 25, 2005 Report Share Posted August 25, 2005 you need to add it as a new server/network. Link to comment
