LOX311 Posted September 18, 2006 Report Share Posted September 18, 2006 Thank you for the nice themes Link to comment
Carlospr Posted September 23, 2006 Author Report Share Posted September 23, 2006 CD Art Display Build 974 (22Sep06) - Lyrics (*) - Small bugs fixed (*) Thanks to Flavio González Vázquez search engine from LYRDB.com CAD has a simple search lyrics feature: 1) Settings: "Control Panel>Download" = here you can set the lyrics folder "Control Panel>Options" = you can set "Lyrics" to the case double click 2) Access: Right click case/cover or tray and select "Lyrics" If you let the Lyrics window open CAD will keep searching and saving the lyrics 3) More: you can edit the lyrics (click "Save" once done); if lyrics is not found you then you can click the status label to browse Google for lyrics (then you can copy/paste and click "Save" once done); click "Details" to change what CAD is searching or select another Result. Not all players have lyrics plugins. This is just an alternative for those like me that'd like to have an easy way to search or even to just read a local lyrics. http://www.closetosoftware.com/temp/cadrc4b974.zip Have fun! More about LYRDB: http://www.lyrdb.com/ Link to comment
Carlospr Posted September 25, 2006 Author Report Share Posted September 25, 2006 CAD RC4 Build 1003 (24Sep06) - Hide Lyrics window - Submit Lyrics Yes now you can submit your lyrics too thus helping LYRDB.com grows! Thanks again to Flavio! http://www.closetosoftware.com/temp/cadrc4b1003.zip Link to comment
Carlospr Posted September 27, 2006 Author Report Share Posted September 27, 2006 CAD RC4 Build 1065+ (26Sep06) - resize lyrics window - format lyrics - set lyrics font, font size, font style - submit lyrics (thanks again to LYRDB.com) http://www.closetosoftware.com/temp/cadrc4b1065.zip Link to comment
theaulddubliner Posted September 27, 2006 Report Share Posted September 27, 2006 great stuff carlosthanks for all your effort and constant development Link to comment
Silverscape Posted September 27, 2006 Report Share Posted September 27, 2006 Carlos:I just did a new clean install on my laptop and installed first the RC4 from your website.Then, after that i installed the latest build from this thread (Build 1065).Then i wanted first to go into the control panel, but when i click in the context-menu on "Control Panel" nothing happens.I uninstalled CAD and deleted everything, reinstalled RC4 and found out, that the last working build where the option "Control Panel" in the context-menu works is the Build 768 !!So i can only use the 768 build if i want to access the control panel.With the newest build the control panel doesn't work.Anyway, thank you so much for this great app and i am looking forward to also use that cool lyrics feature with the latest build! ;-)Cheers,Silverscape Link to comment
LeifL Posted September 27, 2006 Report Share Posted September 27, 2006 Silverscape:http://closetosoftware.com/forum/viewtopic...er=asc&start=15 Link to comment
Carlospr Posted September 27, 2006 Author Report Share Posted September 27, 2006 CAD RC4 Build 1085 (27Sep06) - Lyrics improvements RC 5 will be released soon now. NOTE: see Readme.txt in zip file if you can't open Control Panel or wait RC5. http://www.closetosoftware.com/temp/cadrc4b1085.zip Link to comment
LeifL Posted September 28, 2006 Report Share Posted September 28, 2006 You want RC5? Go to BetaNews and grab it! Link to comment
ichik Posted September 28, 2006 Report Share Posted September 28, 2006 You want RC5? Go to BetaNews and grab it! Thx for the tip. Link to comment
LeifL Posted October 10, 2006 Report Share Posted October 10, 2006 Want the very latest build? Go here: http://closetosoftware.com/forum/viewtopic.php?t=123 Link to comment
