Chazoul Posted May 17, 2006 Report Share Posted May 17, 2006 Hello everybody ! Just one question : How can I write "text" on the windows bar ? Is it with TLB and if yes how can I do that ? -I just wanna make something like on the picture at the bottom, with a different font... Thanks in advance ! Link to comment
nightcrawler1089 Posted May 18, 2006 Report Share Posted May 18, 2006 It depends what function it serves...it could be TLB, or just an AveDesk overlay (which wouldn't detect open windows and occupied taskbar space, so probably not...)-NC Link to comment
camaelion Posted May 18, 2006 Report Share Posted May 18, 2006 Hi, you can also create a link to a Folder on the taskbar, an let windows only show Text, and no Icon... little workaround without an extra program...Camaelion Link to comment
shmengie Posted May 18, 2006 Report Share Posted May 18, 2006 could also be a samurize taskbar config. Link to comment
Nirodha Posted May 18, 2006 Report Share Posted May 18, 2006 Hello everybody !Just one question : How can I write "text" on the windows bar ? Is it with TLB and if yes how can I do that ? -I just wanna make something like on the picture at the bottom' date=' with a different font... Thanks in advance ! [/'] Hi Chazoul, I do it using a Samurize Taskbar configuration. Some people use ObjectBar though, but, I've never really cared for it. Link to comment
Chazoul Posted May 18, 2006 Author Report Share Posted May 18, 2006 Okay, thanks a lot to everybody ! I'll use Samurize Link to comment
akapeso Posted May 23, 2006 Report Share Posted May 23, 2006 Definitely appreaciate the taskbar help Link to comment
lokster Posted June 8, 2006 Report Share Posted June 8, 2006 could you tell me step by step how to? thanks and asides from samurize ne other option? Link to comment
Chazoul Posted June 8, 2006 Author Report Share Posted June 8, 2006 I finally use TLB (shareware) for text on Windows bar. Just create a new Menu, change color, maybe font and this rocks. Link to comment
