kaloyster Posted May 31, 2006 Report Share Posted May 31, 2006 My browser is slowing down by the minute, and I don't know what seems to be the problem. At first when I open it, the mem usage is acceptable, but after a couple of minutes (let's say 10 - 15 mins) when I notice that it's slowing down, I fire up my CTRL + ALT + DEL buttons and there it is: 1xx,xxx MB memory usage (it's the highest of all). I hope someone can figure it out and help me. My specs: - Windowblinds 5 (not sure, but it's the one that supports transparency) - Firefox 1.5.0.3 - SaFire Milk 1.0.9 *My extensions: - NoScript - Adblock Plus - Fasterfox - Adblock Filterset G - Compact Menu - CustomizeGoogle - FoxyTunes - Gmail Manager - Search Plugin Hacks - Searchbar Autosizer - ImageShack right-click - Image Zoom - Flashblock - Tab Mix Plus - Fission - eBay Negs - Titlebar Tweaks - Greasemonkey - Flashgot - VideoDownloader *all of these are updated I suspect that WB5 is causing the slowdown, 'coz when i installed it, that's when the problem started. And i read the About of the WindowBlinds, it says there that it doesn't support the WindowFX 2.19 version, but the 2.5, which will be released later this year (according to the WB Info). I'm using WindowFX as well. PS: I was able to send this message using Firefox's Safe Mode. Link to comment
neal Posted May 31, 2006 Report Share Posted May 31, 2006 Hey kaloyster,someone here gave me this hint once:http://plugindoc.mozdev.org/faqs/memusage.htmlMaybe this helps. Link to comment
kjohnson Posted May 31, 2006 Report Share Posted May 31, 2006 I don't really know what would cause that. That said, my machine is has Firefox using upwards of 120mb with only one window. It's been open for about an hour and a half. Link to comment
camo Posted May 31, 2006 Report Share Posted May 31, 2006 its your cache i bet . try clearing it . ctrl+shift+del Link to comment
kftrainer Posted May 31, 2006 Report Share Posted May 31, 2006 hello Kayloster and kjohnsonI seem to have the same problem with memory just today my firefox crashed my explorer but i do no I am testing the New VLT summer pack O6 for improvements and repoerting on its operation with the residents applications that i have installed , I did try some of the extensions are some work and some did not I did not have too much luck with the Safire firefox extension where I had to cofigure buttons and setting to make it look like Safari -that proved to be a disasster with firefox I do have use now but the memory is still an issue along with instablitly of it at certain times. Do you leave it running for a long time with out using it while you do other tasks on the computer- it takes up space and memory with temporary files which I delete those very factors Link to comment
kaloyster Posted May 31, 2006 Author Report Share Posted May 31, 2006 I noticed while in Safe Mode awhile ago, my mem usage maintains to about 40 - 50 MB. But when using the 'normal' Firefox, and I was watching the Task Manager, the memory just goes up by itself, EVEN IF I'M NOT DOING ANYTHING / LOADING NEW SITES. It's odd. Link to comment
camo Posted May 31, 2006 Report Share Posted May 31, 2006 i had this problem after i updated the extensions . from your list i have are [ fasterfox, image zoom, video downloader, greasemonkey and fission ] it was fixed after i installed earlier version of image zoom ( 0.2.3 ) , disabling lightbox of greasemonkey and uninstalled video downloader Link to comment
ShadyApple Posted May 31, 2006 Report Share Posted May 31, 2006 I noticed while in Safe Mode awhile ago, my mem usage maintains to about 40 - 50 MB. But when using the 'normal' Firefox, and I was watching the Task Manager, the memory just goes up by itself, EVEN IF I'M NOT DOING ANYTHING / LOADING NEW SITES. It's odd.Porn :confused: Link to comment
kaloyster Posted May 31, 2006 Author Report Share Posted May 31, 2006 Uh, no i'm not surfin porn lately.i had this problem after i updated the extensions . from your list i have are [ fasterfox, image zoom, video downloader, greasemonkey and fission ] it was fixed after i installed earlier version of image zoom ( 0.2.3 ) , disabling lightbox of greasemonkey and uninstalled video downloaderHmm.. maybe that's it. I have Grease Lightbox installed. Maybe I'll consider removing it. My Image Zoom is 0.2.5. Can you provide a link for the earlier version? Link to comment
lokster Posted June 9, 2006 Report Share Posted June 9, 2006 its a problem with firefox, a memory leak, as a heavy user with plenty of tabs and windows, it hovers from 110-150mb usage after a few hours of heavy use. with so many plugins im betting thats the reason why. try to unistall and keep the ones ud need. and see if its faster Link to comment
