onomus Posted June 9, 2006 Report Share Posted June 9, 2006 Hi, my opera skin is sorta acting funky. It my be a simple problem but I'm sorta picky when it comes to safari look-a-likes. Here's a picAs you can see the tab bar is over the adress bar. (this is the picky part)For some reason the forward and back buttons are saparated a bit which makes it look sorta ugly. Thanks- Onomus Link to comment
ichik Posted June 10, 2006 Report Share Posted June 10, 2006 If You're using Expedition skin Expedition, then You just have to go to View->Toolbars->Customize, then select the right panel and check the "use large images" option. Link to comment
