imac vs. macbook pro
hi, i need some tips!
i want to buy me a mac. either a 20" imac (maybe a 17" with faster cpu) or a 15.4" macbook pro.
since four years i'm a notebook user and not sure to miss this freedom,
but the imac has some other advantages i think!
so help me out to see more clear, please :)
It really depends on whether you absolutely need it to be portable.
The specs are near identical and the iMac is like a thousand dollars cheaper. I think the iMac is a far better value personally. Plus the iMac doesn't really have any known issues.
Just 100-200$ difference? That's amazing!! Are you sure you are comparing with MacBook Pro, because everywhere I look there's a huge difference.
Answering to your question, I have a 17" iMac and have no complain :) I would say that it's definitely the best option if you're not to miss portability. Larger HDD, screen and (at least here in Spain) a lot cheaper than the MBP, plus if you want to move it from time to time it's not very heavy and you just have to unplug it and take it on one hand and take the keyboard and mouse on the other.
since their both identical in specs ask yourself this, do you want a desktop or a laptop, do you perfer to surf online staying stationary or mobile instead? like dreamsINdigital said wait until the new versions come out and then make your final decision. personally i think ill get the mbp, id rather go to any room in my house and surf the web or take it with me to a park or cafe and surf the web freely. one advantage the imac does have is one bigger screen and two that you can upgrade its cpu so if you see yourself upgrading it in the near future like when intel releases their core 3 duo lol processor then get imac instead.
  • 1 year later...
hey. you guys have a few things wrong on your posts. The mbp has better stats (well the hard drive is smaller but is upgradeable to 160 gb 5400 rpm for only 82$). The mbp has a nivida g force graphics card whereas the imac only has a ati raedon card (significantly less powerful). The mbp also has a 2.2 Ghz processor which is higher than the factory setting on the imac of only 2.0 Ghz (even with the upgrade it is still only 2.16 Ghz)*. Another plus for the mbp is it has 2 gb of ram ( two 1 gb modules) where the imac has only 1. You need to decide not only wether you want something portable but wether or not you will be doing anything heavy such as music production or photography applications. I suggest looking into buying a refurbished 15.4" Mbp as a compromise.
* Assuming you are referring to the higher model 17"
@jordansystem : Do you realize that you are replying a thread almost an year old ???
So their posts, are quite correct for that time.
Although I would like to welcome you to Aqua-Soft.... but your first post (full of ignorance), bumping an old thread doesn't look like a great start.
