Raats Posted July 30, 2007 Report Share Posted July 30, 2007 Quick experiment to make a Leopard Style "crosswalk" sep bar for RK Launcher - using CanasX's ObjectDock mod (http://www.deviantart.com/deviation/59256886/) Replace the existing sep.png with this version. This is not intended to be a definitive sep bar. I only wanted to see if it would work - and it does .... Link to comment
Markoz Posted July 30, 2007 Report Share Posted July 30, 2007 Thanks...! People will like this! Link to comment
Mac Intosh Posted July 30, 2007 Report Share Posted July 30, 2007 That's pretty cool. I wish I could have a leopard dock in Mac OS X. Link to comment
squirt33 Posted July 30, 2007 Report Share Posted July 30, 2007 Mac Intosh:You can:http://www.deviantart.com/deviation/57706188/ Link to comment
lostfan Posted July 31, 2007 Report Share Posted July 31, 2007 It doesn't work for me.... when I open the Separator png in picture viewer, there's nothing there, it's just like a transparent image. And when I add it into the theme folder, there's no separator in the dock. There's a space between the icons but you just can't see the "abbey road" separator.ETA: nevermind, now I get it. *d'oh!* Link to comment
Linwe Posted July 31, 2007 Report Share Posted July 31, 2007 Anyone knows how to get it working on ObjectDock? Link to comment
Mac Intosh Posted July 31, 2007 Report Share Posted July 31, 2007 Mac Intosh:You can:http://www.deviantart.com/deviation/57706188/Thank you so much Link to comment
soccerpro100cn Posted August 6, 2007 Report Share Posted August 6, 2007 hmmm yea does any one know how to get CanasX's rk launcher theme on objectdock? i've been trying to modify the txt file so it would work but no luck. Link to comment
Markoz Posted August 6, 2007 Report Share Posted August 6, 2007 i NEVER Tried my theme on OD, i don't use it.The closest you can to my theme is reverse84's themes. Link to comment
Linwe Posted August 6, 2007 Report Share Posted August 6, 2007 Nobody can tell me how to use this separator in OD?I'm using reverse84 theme! Link to comment
KAWSquared Posted August 6, 2007 Report Share Posted August 6, 2007 mac developers are so clever Link to comment
Bebi_Bulma Posted August 6, 2007 Report Share Posted August 6, 2007 Nobody can tell me how to use this separator in OD?I'm using reverse84 theme!Just make an empty shortcut as use the separator as the icon, that's how I do it. Link to comment
Linwe Posted August 6, 2007 Report Share Posted August 6, 2007 But I am using the ObjectDock "Dock TaskBar" so if i do it i see 2 separators... the crosswalk one and the empty one. I can't remove the separator to the Dock TaskBar. I've tried messing around with .ini files with no luck. Can somebody tell me how to integrate it with the reverse84 theme? (which, btw, has no sep image). I don't know too much about OD since i switched from RK Launcher a few time ago. Anyway thanks for the suggestion, Bebi_Bulma! Link to comment
Markoz Posted August 6, 2007 Report Share Posted August 6, 2007 Nobody can tell me how to use this separator in OD?I'm using reverse84 theme!I thought i heard you can use KKmenu for Rocketdock, and maybe my theme with the sep and everything..So, that means, Switch to RocketDock.. Link to comment
soccerpro100cn Posted August 6, 2007 Report Share Posted August 6, 2007 but that would be hard i mean it would be hard to get all of the icons back and all. it would take too much time. im using the same dock theme as linwe is and nothing will work right.[[Edit]]oh and the seperator comes up rly small so that is another problem.sry for bad spelling im typing this on my wii Link to comment
tehloxely Posted August 7, 2007 Report Share Posted August 7, 2007 It's nice. It just seems a little too thick, to me. Link to comment
Mike3300 Posted February 29, 2008 Report Share Posted February 29, 2008 Just add a new separator in ObjectDock. Right click and click Add, then add Separator. Basically you're replacing the image with that given by thread starter. Link to comment
yougotmail Posted March 2, 2008 Report Share Posted March 2, 2008 That is pretty nice indeed. Link to comment
