Memory Monitor Docklet
Smaky
I have just finished the fist beta of this new docklet. Again, since Systats does not work on my vista system I have decided to create docklets that will monitor my system a-la Systats.
This docklet displays a usage bar (arc actually), and some text usage (either free or used memory).
Just finished it... but I wanted to share it with you so I can get some feedback.
The icon is based on my previous VolumeDocklet:
http://www.aqua-soft.org/board/showthread.php?t=49321
As I have already said... I am not a desinger... just a simple programmer, so any help from the graphic icon designers out there will be really appreciated.
Update 08/04/2008 - Fixed a bug (presumably) that prevented the docklet from showing the correct amount of RAM for System with more than 2 GB of Memory.
- Added a Detailed information dialog that show Physical Memory, Paging File & Virtual Memory usage.
Yoy may download the docklet from:
http://www.feterspace.com.mx/downloads/MemoryMonitor.zip
Give it a try... all commentas & suggestions are quite welcome.
  • 10 months later...
