Phixtit Posted June 18, 2010 Report Share Posted June 18, 2010 I'm wondering if anyone on this forum knows how I can uninstall XWindows Dock 2.0.2.0? I'm not satisfied with it, & want to remove it completely from my computer. (All Files & Registry Keys).I've completely searched the forums & can't find the uninstallation information anywhere.Any help on this would be greatly appreciated! Link to comment
Elevati0n Posted June 18, 2010 Report Share Posted June 18, 2010 (edited) just delete the folder where you have XwindowsDock and c:\Users\name\AppData\Roaming\XWindows Dock\ if you have Win 7. That;s it.Why aren't you satisfied with?It's not like XWindowsDock 5.6.....it's smth else. ..much better...but for now it's not finished. The Author has a lot of work to do...School, private life...so... Edited June 18, 2010 by Elevati0n Link to comment
Phixtit Posted June 21, 2010 Author Report Share Posted June 21, 2010 just delete the folder where you have XwindowsDock and c:\Users\name\AppData\Roaming\XWindows Dock\ if you have Win 7. That;s it.Why aren't you satisfied with?It's not like XWindowsDock 5.6.....it's smth else. ..much better...but for now it's not finished. The Author has a lot of work to do...School, private life...so...Thanks for the help! The reason I'm Uninstalling this is because it's missing a feature I can't do without.That feature is: AutoHide. My screen is small enough as it is & I need to use as much of it as I can.If this feature was added I would definitely Uninstall Rocketdock & Install XWindowsDock. Link to comment
