Aqua-soft V3 Skin Download [vb3.5, Vb3.6 & Phpbb2]
Installation instructions, for vBulletin 3.6.8
1. First upload the as3 folder of images to your site. ( ~/forums/images/ folder goes here. )
2. Next Login to the admin panel of your forum. Select Download/Upload which is under Styles.
3. Once there, select the browse button and find the file Aqua-Soft v3 Style.xml.
4. After that go ahead and press the Upload button. And then the style will be installed.
5. To make the skin the default skin, click Modify under Styles and find the Aqua-Soft v3 skin and set it as the Default skin there.
Installation Instructions, for phpBB 2.x
1. First upload the AquaSoft folder to your site. ( ~/phpbb/templates/ folder goes here. )
2. Next Login to the admin panel of your forum. Under Styles Admin select Add.
3. Once there, you should see a list of themes currently NOT installed on your forums. Click on Install next to the AquaSoft skin. And that's it! The skin is now installed and ready to be used.
4. To make the skin the default skin, click Configuration under General Admin and find the AquaSoft skin in the drop-down menu for the default skin.
This post will be updated when a new version is out. So to stay up to date with releases you can subscribe to this thread.
Aqua-Soft v3 Skin phpBB2.zip
Aqua-Soft v3 Skin vB35.zip
Aqua-Soft v3 Skin vB36.zip
  • 1 month later...
  • 3 months later...
  • 1 month later...
Updated 05-12-07
- vBulletin version has been updated to the 3.6.6 release.
- Updated images to reflect changes to 3.6.6.
- Slight CSS optimizations. (sprite image for shadow instead of multiple images)
- Added a PSD for the basic wrapper of the site. (useful for those who want to change the background color)
Recommended Update, if you plan on using the latest release vBulletin 3.6.6 use this version of the skin.
  • 2 months later...
Updated 07-29-07
- vBulletin version has been updated to the 3.6.8 release.
- Misc Template changes added extra toolbar icons if needed.
- phpBB version updated to fix the alternating row bug. (index_body.tpl)
  • 2 months later...
Updated 09-30-07
- Unified Toolbar Versions Added (Sub Styles of Aqua-Soft v3 Style.xml)
- Misc Images added/replaced, see notes below.
Download: [attach]10730[/attach]
phpBB 2.x will not be updated anymore aside from bug fixes. It will be replaced with the phpBB 3.x version once phpBB 3 goes final. Which will have the unified toolbar by default. So just a heads up.
Notes: (Updated vBulletin images)
as3/search_box.gif
as3/unified_caption.gif
as3/unified_icons.gif
as3/unified_site_logo.gif
as3/unified_toolbar_bg.gif
as3/gradients/gradient_lite_thead.gif
as3/misc/navbits_finallink_ltr.gif
as3/misc/navbits_finallink_rtl.gif
as3/misc/navbits_finallink.gif
as3/misc/navbits_start.gif
as3/statusicons/forum_link.gif
as3/statusicons/forum_new_lock.gif
as3/statusicons/forum_new.gif
as3/statusicons/forum_old_lock.gif
as3/statusicons/forum_old.gif
as3graphite/search_box.gif
as3graphite/unified_caption.gif
as3graphite/unified_icons.gif
as3graphite/unified_site_logo.gif
as3graphite/unified_toolbar_bg.gif
as3graphite/misc/navbits_finallink_ltr.gif
as3graphite/misc/navbits_finallink_rtl.gif
as3graphite/misc/navbits_finallink.gif
as3graphite/misc/navbits_start.gif
as3graphite/statusicons/forum_link.gif
as3graphite/statusicons/forum_new_lock.gif
as3graphite/statusicons/forum_new.gif
as3graphite/statusicons/forum_old_lock.gif
as3graphite/statusicons/forum_old.gif
Guest
This topic is now closed to further replies.
