Aqua-soft V4 Skin Download [vb3.7 & Phpbb3]
Last Updated: 9/6
For vBulletin 3.6 and phpBB 2.0 see this thread.
Note: This is not a free skin, you can purchase it here.
Installation instructions, for vBulletin 3.7
  1. First upload the as4 folder of images to your site. ( ~/forums/images/ folder goes here. )
  2. Next Login to the admin panel of your forum. Select Download/Upload which is under Styles.
  3. Once there, select the browse button and find the file Aqua-Soft v4 Style.xml.
  4. After that go ahead and press the Upload button. And then the style will be installed.
  5. To make the skin the default, click Modify under Styles and find the Aqua-Soft v4 skin and set it as the Default skin there.
Installation instructions, for phpBB 3.0
  1. First upload the contents of the phpBB3 Skin folder of images to your site. ( ~/forums/styles/ style.cfg and the 3 folders go here. )
  2. Next Login to the admin panel of your forum. Select Styles tab which is at the top.
  3. Once there, you should see a list of installed and un-installed skins. Find the Aqua-Soft skin, to the right of that select Install.
  4. Then select the settings for the skin you want and press the Submit button. Thats it, the skin should now be installed.
If you feel there are any templates you think maybe missing, do let me know. It is easy to overlook certain sections of the forum.
A lot of time has been put into this skin. I ask that you do not redistribute this without permission. And lastly feel free to donate.
8_27 Patch vB 373.xml
8_27 Aqua-Soft v4.zip
9_06 Aqua-Soft v4 phpBB3.zip
12_29 Aqua-Soft v4 phpBB3.zip
  • 3 weeks later...
Updated 7-28-08
- Fixed caption bar, where if users didn't specify site name, it would screw up the logo and toolbar items.
- Fixed CSS issue, where some of the css was not included within the xml file.
- Renamed graphite_progress.gif to graphite_progressbar.gif (images/as4/misc/)
Note: For those who do not wish to update, please add the following to your CSS, some vb installs did not import the following.
.bigusername { font-size: 15px; }
td.thead, th.thead, div.thead { padding: 4px; }
.pagenav a { text-decoration: none; }
.pagenav td { padding: 2px 4px 2px 4px; }
.shade, a.shade:link, a.shade:visited { color: #777777; text-decoration: none; }
a.shade:active, a.shade:hover { color: #ff4400; text-decoration: underline; }
.tcat .shade, .thead .shade, .tfoot .shade { color: #dddddd; }
.fieldset { border-color: #8b8b8b; border-style: solid none none none; border-width: 1px 0px 0px 0px; margin-bottom: 6px; }
.fieldset legend { padding-left: 8px; padding-right: 8px; }
.fieldset, .fieldset td, .fieldset p, .fieldset li { font-size: 11px; }
  • 5 weeks later...
Updated 8-27-08
- Fixed bug where posted by text would not show when no post title set.
- Added banner locations for signature and first post message.
- Updated template changes for vBulletin 3.7.3
Note: You can use the patch in the first post, to upgrade your skin to vbulletin 3.7.3 if you were already using the latest version prior to this update. If not, please use the regular skin package and upgrade from that.
Updated 9-5-08
- First release of the phpBB3 version of the skin (BETA)
Updated 9-6-08
- Fixed control panel tab navigation in IE6
Updated 12-29-08
- Fixed numerous IE6 and Firefox2.x css bugs
- Fixed profile and ucp tab problems
- Misc tweaks
Note: Since this is the first version of the phpBB3 skin, there will be bugs, this is a beta so please report anything you feel is out of place.
List of Current Bugs
- Moderation Pages are un-skinned
- Font size changer does not work correctly (currently hidden in the toolbar)
- Misc sections are un-skinned
Guest
This topic is now closed to further replies.
