matonga Posted January 9, 2009 Report Share Posted January 9, 2009 Skin Editor Download: http://matias.securityconsultant.com.ar/XWDSkinEditor.zip Install: Extract .exe file into C:Program filesXWindows DockTools (or wherever XSkinMaker.exe is, and ..SkinsSkin.smxd is valid) Warnings: I'm not held responsible of any direct/indirect bla bla bla, you understand. Not thoroughly tested. You're a coder?: http://www.matiasmoreno.com.ar/XWDSkinEditor-sources.rar If you modify the program, and publish better version of it, please publish also sources so anyone can continue improving on it. Link to comment
skdj Posted January 9, 2009 Report Share Posted January 9, 2009 Una vez mas con un gran aporte karnal! En vdd hacia falta algo asi! Gracias!!!Ahora si señores... a poner a trabajar toda la kreatividad!Once again a great share, We where missing an app like that one, ThanksLet´s do it ppl, get you creativity on work! Link to comment
zequihumano Posted January 9, 2009 Report Share Posted January 9, 2009 simply genius, thanks. I love the icon BTW JK Link to comment
shishimaru Posted January 9, 2009 Report Share Posted January 9, 2009 Wow! Thanks. Everyone can use this without any help file Link to comment
baconissweet Posted January 9, 2009 Report Share Posted January 9, 2009 Wow cool job, I applaud this. Link to comment
yorkey Posted January 9, 2009 Report Share Posted January 9, 2009 Wow! Pretty snazzy! Thanks alot Matonga Link to comment
atreiu Posted January 9, 2009 Report Share Posted January 9, 2009 OMG. Skinning is so easy with it, now even I can do it Thanks A LOT, Matonga. EDIT: One thing I'm missing: is there a way to extract the single .png-files? That would be really helpful for people like me, who just want to edit some of the .pngs. And if reflection-offset would be reflected in the preview, than it would be perfect Link to comment
Elevati0n Posted January 9, 2009 Report Share Posted January 9, 2009 Wow...Matonga did it AGAIN Now...let's startin' to make new awesome skins ) Link to comment
gogsythreat Posted January 9, 2009 Report Share Posted January 9, 2009 Thanks Matonga excellent again Link to comment
AndrewYY Posted January 9, 2009 Report Share Posted January 9, 2009 100/10 I'm loving this Link to comment
KornVoli Posted January 10, 2009 Report Share Posted January 10, 2009 Thank you, all quick and easy! Link to comment
Denis7OO Posted January 10, 2009 Report Share Posted January 10, 2009 I've made an icon for this app, tho it needs it. If you like it feel free to use it. Holla XWDSkinMaker ICO.zip Link to comment
WhiteFlash Posted January 10, 2009 Report Share Posted January 10, 2009 It`s amazing Thank you Link to comment
matonga Posted January 12, 2009 Author Report Share Posted January 12, 2009 New features:- Right click a picture, then choose Save as and you can save individual pictures from a skin for later modification or whatever.- New icon by Denis7OO (thanks man!) Link to comment
Panta Posted January 12, 2009 Report Share Posted January 12, 2009 Hi matonga!Just found a bug: at the preview, Indicator.png isn't being scaled. I can post a screenshot if needed.Edit: the same for Break.png.Edit2: forget about the above edit... :slant: Link to comment
atreiu Posted January 12, 2009 Report Share Posted January 12, 2009 New features: - Right click a picture, then choose Save as and you can save individual pictures from a skin for later modification or whatever. - New icon by Denis7OO (thanks man!) Thanks a lot for this update, matonga Link to comment
bSAYZ Posted January 12, 2009 Report Share Posted January 12, 2009 Great app & icon..Thankz Link to comment
Deavy Posted January 12, 2009 Report Share Posted January 12, 2009 Matonga, thanks for visual skin editor But: Small icon (16x16) look not good, maybe need to simplify it. 32x32 looks better, but I think, that need to delete dock from it. Link to comment
matonga Posted January 12, 2009 Author Report Share Posted January 12, 2009 Hi, new update: now it also previews 2D skins. Edit: I forgot to mention preview now is drawn with bilinear (panels) and highest (icons) interpolation quality. @Panta: I don't know what to scale the indicator with. I will try by trial & error later. Break.png is being scaled, though I dunno I'm doing it correctly or not. @Deavy: I don't have time to perfect the app's icon. It's up to Denis7OO or someone else having enough time to do it. Indeed if you have some old copy of the app, look at the original icon (which was drawn by me... and it was terrible). Link to comment
ciano Posted January 12, 2009 Report Share Posted January 12, 2009 I dunno but I can't save a New skin that I mde or also a modified one...the SAVE btton is always disabled... Link to comment
Denis7OO Posted January 12, 2009 Report Share Posted January 12, 2009 as soon as I will come back from university I will perfect the icon, tho holla Link to comment
Panta Posted January 12, 2009 Report Share Posted January 12, 2009 Using Denis700's PNG I've created an icon (.ico) 16x16 up to 256x256/Vista. Warning: it contains all possible sizes, so it's not that small... (324KB)Get it here: http://e.imagehost.org/download/0691/XWDSkinEditor Hope this helps.@matonga: you can try using the bounding rectangle from the bottom of the dock to the top of icon region; I think this is the right reference... Link to comment
