Timan Posted February 25, 2009 Report Share Posted February 25, 2009 Last Updated: 02/6/10 For vBulletin 3.7 and phpBB 3.0 see this thread. For vBulletin 3.5, 3.6 and phpBB 2.0 see this thread. Note: This is not a free skin, you can purchase it here. Installation instructions, for vBulletin 3.8.2 First upload the as4 folder of images to your site. ( ~/forums/images/ folder goes here. ) Next Login to the admin panel of your forum. Select Download/Upload which is under Styles. Once there, select the browse button and find the file Aqua-Soft v4.5.xml. After that go ahead and press the Upload button. And then the style will be installed. To make the skin the default, click Modify under Styles and find the Aqua-Soft v4.5 skin and set it as the Default skin there. Installation instructions, for Invision Power Board 2.3.6 First Login to the admin panel of your forum. Select the Look & Feel tab at the top, and then click on Skin Import/Export in the left menu. Scroll down to where it says Import Skin Templates. Browse for the ipb_skin-as4.xml.gz file and press Import Skin XML Once the skin templates are done importing, go back and Import the Skin Images using the ipb_images-as4.xml.gz file. Before you press import, make sure the Aqua-Soft Skin is selected for the skin set to use the images with. When you've done that, press Import Skin Images And finally you must Import the Macros using the ipb_macro-as4.xml file, and select the Aqua-Soft Skin as the skin set to use the macros with. Note: To get your forums to look as they do here, please check out the Mods.html file in the package. Installation instructions, for phpBB 3.0.6 First upload the contents of the phpBB3 Skin folder of images to your site. ( ~/forums/styles/ style.cfg and the 3 folders go here. ) Next Login to the admin panel of your forum. Select Styles tab which is at the top. Once there, you should see a list of installed and un-installed skins. Find the Aqua-Soft skin, to the right of that select Install. Then select the settings for the skin you want and press the Submit button. Thats it, the skin should now be installed. If you feel there are any templates you think maybe missing, do let me know. It is easy to overlook certain sections of the forum. A lot of time has been put into this skin. I ask that you do not redistribute this without permission. And lastly feel free to donate. IPB23_Aqua_Soft_v4.5.zip vB3.8_Aqua_Soft_v4.5.zip phpBB3 Aqua-Soft v4.5.1.zip Link to comment
Timan Posted February 25, 2009 Author Report Share Posted February 25, 2009 Updated 02-25-09- First release of the IPB version of the skin- Updated the vBulletin verison to work on version 3.8Note: Since this is the first version of the IPB skin, there may be bugs; So please report anything you feel is out of place.List of Current BugsvBulletin- Few Template errors for Social GroupsphpBB- Moderation Pages are unfinished Link to comment
Timan Posted March 4, 2009 Author Report Share Posted March 4, 2009 Updated 03-04-09- Fixed a few templates that did not get imported correctly (messenger templates)List of Current BugsIPB- Classic profile is the only part skinned, the enhanced profile will be done shortly. Link to comment
Timan Posted April 2, 2009 Author Report Share Posted April 2, 2009 Updated 04-02-09- vBulletin version updated for 3.8.2, not a required update. Templates changed have no effect on the skin. Link to comment
Timan Posted April 10, 2009 Author Report Share Posted April 10, 2009 Updated 04-10-09- Fixed numerous IE6 issues with the vBulletin skin.- Added Tiger Skin for the phpBB3 version (by request). as4_tiger Link to comment
Timan Posted February 6, 2010 Author Report Share Posted February 6, 2010 Updated 02-06-10- Fixed phpBB3 Moderation templates Link to comment
